griezy
- Jan 8, 2014
- 200
- 87
- 28
- Location
- somewhere
- 1982 VH SL-X Wagon
the past year or so ive been collecting all the hundreds things needed for the conversion, so many small things, anyways ive just about got everything now, (the hardest thing I find hard to get is the early type metal hoses that go from the rack to the rubber hoses, ive just found a NOS high pressure metal pipe but still in need of the low pressure pipe ( not the hose from the pump)
I know the vk set up with the external reservoir is easier to get but i can not use the late VH- VK set up as my aircon compressor is where that system goes on the passenger side
originaly the wagon did have power steering in it but someone in the past changed the rack when they installed the black 6 motor from a VK
my question is, what pump do i have? its a squarish stile, is it metric or Imperial pump?
also all these parts are second hand which most had some shelf life, is there some way to properly clean everything out before installing (the reason i ask is because when in the past i took my steering box out of my old HQ to paint it up and put it back in after turning the wheel side to side to bleed it, it always went to the right by it self, found out some small partical crap fell into it
