Removing and Replacing Springs in a VZ
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by SV6, May 23, 2008.
  1. SV6
    SV6 New Member
    Melb
    VZ SV6 A5
    Hope this is the right section for this question...
    From what I have read elsewhere on this site people have been removing wheels and shockers etc to change the rear springs.
    I watched as a suspension place hoisted my car up and changed the rear springs in my SV6 without removing anything. Took him about 2 mins each side to change.
    I now want to change them again, and was thinking about this as my plan of attack...
    - Place wedge under both front wheels
    - Remove handbrake
    - Get trolley jack and jack rear of car as far into the air as possible
    - Pull down on the top of the spring to make it become uncaptive
    - Remove springs
    - Replace with new springs
    - Lower car
    - Enjoy
    Is this a far too simplistic approach?
  2. naf33n
    naf33n go
    The Shire
    Supercharged VU SS
    yeap sounds like a good plan...if ur lucky the springs will actually fall out.. depending on how low your current springs are. fe2 can be pulled out and standard springs are the ones that take a bit of effort.
  3. SV6
    SV6 New Member
    Melb
    VZ SV6 A5
    Current springs are Kings Springs SL's so pretty short.
    Am I not missing anything with this plan though?
    I think when the fitted these ones they may have used a bit of grease on the ends????? Would that be correct??? Why?
  4. naf33n
    naf33n go
    The Shire
    Supercharged VU SS
    mmm never heard of using grease before. as long as you still have the rubber bump stop covers there shouldnt be any need for it...
    but at the end of the day its a pretty simple job and shouldnt take you any longer then 15 mins..
    oh btw one more thing you may need to consider, depending on how low you go. you might need a smaller jack.(eg the normal car one) i know with my car i have to jack it up a little bit with the normal jack, then once its high enough for the trolley jack i use that
  5. Torquative
    Torquative Sports Economy
    VE SV6 3.6L SIDI 6sp
    yes, I fail to see the standard "consume alcohol" part!
    Dont know about you but anytime Ive worked on a Commodore, whether mine or someone elses, theres been time allocated to unscrew bottle top, pop in stubby holder ... lol
    Nah seriously that sounds about right from what Ive heard and observed. Not a very difficult process at all
    Can I ask why are you changing them? Done their time? Or just going lower/higher??
  6. SV6
    SV6 New Member
    Melb
    VZ SV6 A5
    I am just swapping over from SL's to SSL's to see how it looks. I like how it sits now, but I might like it more after I swap them.
  7. Torquative
    fair enough!! I wanna see lots of before and after pictures :thumbsup:
  8. vz 914
    vz 914 New Member
    VE HSV GTS , VZ UTE, VL GROUP A
    Dont super low springs require shorter shocks to stop this very problem ????(springs becoming loose when car is jacked up)
  9. naf33n
    naf33n go
    The Shire
    Supercharged VU SS
    yeah shorter shocks would stop it. but also leaving the handbrake on whilst jacking the car up stops it as well.. had mine for over 2 years with out any dramas
  10. SV6
    SV6 New Member
    Melb
    VZ SV6 A5
    What spring combo are you running mate?
    Wheel size?
  11. naf33n
    naf33n go
    The Shire
    Supercharged VU SS
    mmmm not sure on the spring size as i told the guy where i wanted the car to sit(instead of i want SL's or SSL's etc) but the front just sits inline with the tyre and the rear it is just off the rim, so there is a a nice amount of tyre tucking under the guards.
    btw rims are 19's/ 245 tyres
  12. adomski
    adomski New Member
    Newcastle, NSW
    VZ Commodore 3.6L
    Yes and no.
    Yes: It is fairly simple concept, spring comes off with the right amount of force when shock removed / spring expanded as much as possible.
    No: Its not as easy if you're attempting with STOCK springs as they are higher than lowered springs (obviously).
    It also could put you in a pickle if you for whatever reason need to put the stock springs back on (your lowered springs don't fit, break, etc.
    This would be a nightmare if you stuff up without spring compressors...also not to mention the safety issues with inexperienced home mechanics. Nobody likes a spring to the face!
    I'd personally rather just put the little extra time and effort into spring compressors and know that it'll get done properly.
    Hope this helps. :)
