replace brake light switch
vt16
vt executive
i've been told i need to replace my brake light switch in my 99vt exec, can someone tell me what this is and how to replace it please. i know its somewhere on the end of the brake pedal where it goes up under the dash, just need to know what im looking for and how to remove it. your input would be helpful. thankyou
GMMAD
Nowra
3.8L GT35 4runner/VK calais
its on the top of the brake peddle,it just screws in
it has a little button on the end of it like the interior light button inside the door
you cant miss it
katsevreston
adelaide
vy calais 5.7
i've been told i need to replace my brake light switch on a vy holden did that but still no brake lights can some please help
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
Did you check the actual globes and fuse first?
st3r3otyp3
Donating Member
VX HSV VX SS
Ok if you have cruise control there will be two brake controllers down there the cc switch has 2 electrical inputs ports (fig 1) one may be free as this is for trailers with electric brakes , and the brake light switch has one electrical input (fig.2).
Also the main reason these fail is because the button gets gummed up and seizes so when you take it off test the button funtion if its stiff or stuck you can repair it, the switch is two parts joined by plastic wing clips use a flat blade screw driver to take it apart then clean and lube (dry lube).
I did this to my SS last week.
Figure 1.
figure 2
shueardm
VZ SV6
thanks for the image above, I know what to replace now
