Replacing rack ends - Can I do it myself?
azkwazere
Ahhh Yes, Ahhh Yes....
.....SE Burbs
VP 5-SPD / 24-SPD Racer Hybrid
SweetWagon
booosted
35
Springwood NSW
VS Berlina Wagon Supercharged
and your sure that its not worn ive seen the have to be shimmed before
The rack itself, who knows its probably the original one on its way out but still it shouldn't cause noises driving straight, pretty certain the new rack end will fix the knocking issue. If not.. well ill worry about that :p
Morton
For external use only
Fairstar the Funship
Just pull everything out and wiggle it all :p
SweetWagon
booosted
35
Springwood NSW
haha trust me it has crossed my mind. Even if the new rack ends fix the problem ill be looking into a manual steering rack in future. Just unsure what do do with the P/S pump, cant run the belt without it. Do you know what to do with those lock washers Morton?
vn calais manual
35
vn calais, vs clubsport #137
just make a bracket to accept the ps pump pulley as another idler. ;)
Morton
Pretty sure you have to run a dummy idler without power steering on the old buick.
The lock washers you can grab from any steering specialist, my bloke gave me a handfull for free. Take note of how they sit on your current rack ends. The new ones will be flat. Once they're in there (they lock into the rack end), and the rack end is tightened up to about 80nm (or just as tight as you can bloody well get them), then smash the ends of the washers down with a small hammer, so they "lock" around the flat parts of the rack :)
And you're done!
Keep in mind you have to pry back the old lock washers before you can remove the rack ends :)
