replacing VS antenna
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by existentialist, Nov 25, 2006.
  1. existentialist
    existentialist New Member
    VS
    hey
    I need a new antenna for my VS since it's been broken off and the whole extension/retraction mechanism seems to be missing...
    what's the cheapest place to get a one? are new ones preferable to old ones?are they easy to install?
    any advice would be appreciated
    cheers
  2. POVRTY
    POVRTY building 5L VB TH 400
    taree nsw
    VE SSV 6SPD WGN
    not that hard to install your self. To give your self a bit of room take the front left wheel off and pull the plastic inner gaurd out or it bend fairly well. the cable connects inside the car at the passengers feet. its a black cable. if it is electrical ther will be some elec plugs just swap em over! its no real hard its def worth having ago at!
  3. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    VF2 GTS A6, VS Calais 383 A4, VS Clubsport 185 A4
    I found that Autobarn were the cheapest for a new unit.
