You can adjust the spring tension on the secondaries. This should be done in very small increments as it will bog down if it is softened too much. 1/8 of a turn at a time.
Do this by backing of the locking allen bolt while holding the screw, then loosen the screw for earlier or tighten for later actuation.
View attachment 247998View attachment 247997
yes.. that is a possible but it is at the END of a long list of things to try
don't do this first up, you have to check/fix the basics
first thing.. do your secondary throttle valves actually open? have seen carbs that they never open on and you will never got the air valves to work if they dont
then is the secondary airvalve shaft seized? does it allow free movement by the air valves? Distort the top cover by overtightening and hey... secondary air valves will not open
and
related.. do you have a working secondary air valve cam? the cam in the middle? is it jammed? they do ...
do you have a secondary pulloff that works as it should? if not, mostly likely jammed and the air valve will never open
does this have the correct vac signal so it allows the secondary air valves to open when they should
is either vac break (front or rear) holding the choke in the wrong place?
is the float height correct?
is the fuel pump up to supplying the carb? (test it.. no lower than 4psi please)
is the fuel inlet filter blocked? starving the carb
is the power piston stuck or jammed?
and is the APT adjustment correct for that carb?
are the primary needles straight and seated correctly ?
is there dirt/crud in the bottom of the fuel bowl?
is the check ball worn? (there is only ONE on a Quaddie)
also other simple stuff, is the cable actually opening all the bits it needs to? (don't larf, an incorrectly set cable may only give 70% performance)
no air leaks.. in the bottom throttle body gasket?
no air leaks in the throttle bottom cross shaft? (just rebuilt 2 Quaddies that had this problem, they were worn so rebushed the shaft)
is the secondary lockout adjustment correct?
is the secondary OPENING adjustment correct?
is the secondary CLOSING adjustment set correctly?
and NOW...we do the air valve spring adjustment outlined above
that help???
ps... in the middle of rebuilding 3 Quaddies and they are the tests I check/perform on all rebuilds
