SAFEBRAKE Custom-Kit braided lines - VR-VS with VT calipers
Discussion in 'SAFEBRAKE Performance Brake Lines' started by braidguy, Dec 18, 2012.
  1. braidguy
    braidguy Member
    Hi VR-VS folks,
    Do you want to "EXPERIENCE SUPERCAR BRAKING IN YOUR DAILY CAR, ORIGINALLY RESERVED FOR TOP-END SPORTS-CAR & RACING CAR". Or do you like your car to have the capability of "UNRIVALLED BRAKING PERFORMANCE FOR ROAD OR TRACK, REGARDLESS OF THE SIZE OF CALIPERS OR DISC".
    Then SAFEBRAKE product is the way to go.
    This SAFEBRAKE Custom-Kit braided lines is for Commodore VR-VS. The end-fittings such as Banjo, Female, Centre mount grommet and chassis bracket are all original design. As good as original replacement parts, this kit installs just like your original lines do. I like to say, "It fit like original".
    Front lines are 50mm longer to suit the larger discs. The Banjo end-fitting is to suit VT calipers. Installation instruction is included to ensure the installation is easy. Even if you have lowered suspension, our installation method ensures perfect installation.
    Product Code:
    HCVS/CS-93.7-VT-TF Suit VR-VS with live-axle 1993-1997, fitted with VT front calipers.
    HCVS-93.7-VT-IRS Suit VR-VS with IRS 1993-1997, fitted with VT front calipers.
    The kit consist of the following lines;
    Front LH axle = x 1
    Front RH axle = x 1
    Rear LH axle = x 1
    Rear RH axle = x 1
    Rear chassis to axle LH = x 1
    Rear Chassis to axle with splitter bulkhead RH = x 1
    Total = 5 lines kit (For VR-VS with live-axle)
    = 6 lines kit (For VR-VS with IRS)
    What make SAFEBRAKE braided lines the best performance brake lines?
    √ ADR 42/04 Compliant,
    √ SAE J1401 Compliant,
    √ OEM Specification made according to individual car model,
    √ SAFEBRAKE Teflon® Line is Certified ISO TS16949:2009,
    √ Robust 3.4mm Heavy Wall Teflon® Inner-Lining,
    √ Every line is tested to 3,500 psi.
    Hose Construction
    - Designed with robust 3.4mm heavy wall Teflon® Inner-Lining to eliminate hose expansion which affecting brake performance.
    - Manufactured with 100% pure Teflon® powder supplied by DuPont™ FlouroPolymer Solutions.
    - The extrusion process utilise patented technology which results in consistent wall thickness and inner diameter.
    - No added pigments or additives which may reduce the strength of the line.
    - Teflon® inner-lining is reinforced with stainless steel wire braids which is constructed in 'high-density' cross-braiding pattern that ensure ultimate structural strength of the line.
    - The braid wires are produced from top quality AISI 304/S15 or BS970-1 1996 hard drawn tensile stainless steel
    Extra Protection
    For protection from weather elements and road debris during the working-life of the line, an external layer of PVC elastomer (Elastic Polymer) is incorporated to protect the stainless steel wire braid.
    SAFEBRAKE metal end-fittings are made of high quality carbon steel which are machined with precision, utilising the latest machining technology as required by ISO/TS16949 (Automotive OEM Supplier Standard).
    Environmental friendly Zinc coating is used to protect the metal end-fittings to ensure long service life and compliance with environmental protection laws.
    Key Advantages
    - Unrivalled flex-life (18 million normal cycles) for exceptional durability.
    - Minimal volumetric expansion (hose swelling) due to 3.4mm Heavy-Wall designed which results in powerful braking and amazing feel.
    - Negligible water ingress, meaning brake fluid is not contaminated and performance is not compromised.
    - Long service life while maintaining the same high level of braking performance.
    - Safer motoring - Improved braking performance over standard rubber brake hose.
    - Unrivalled braking performance for track and racing application, regardless of the size of brake rotors and calipers.
    Customer's Feedback
    Following are customer's comment from their experience of using SAFEBRAKE brake lines products;
    - Obvious improvement in brake performance of their car, right after installation.
    - Helps to reduce overall stopping distance.
    - Able to reduce the speed of their car more confidently in wet or dry road condition.
    - Able to get out of dangerous situation more confidently with precise brake and vehicle control.
    - Reduce swerve tendencies during panic or emergency braking, even on older cars.
    Ask me question if you have any. If you upgrade the rear calipers as well, just let me know. I can make custom-kit to suit any calipers such VE with original fittings and the whole kit still fit like original VR-VS lines.
    EMAIL ME : safebrake@hotmail.com
    Cheers!
  2. Cava454
    Cava454 Member
    Box
    VR SS, VZ SS
    How much...
  3. ephect
    ephect Donating Member
    VS Acclaim V6
    ^^^ this
    And do U have a kit for the C4 calipers, used on the hsv 215i models with 328mm rotors.. If so how much
  4. acarmody
    acarmody Donati..Whoa Green
    VX Berlina
  5. immortality
    immortality Donating Member
    Sth Auck, NZ
    Not bad really when you consider that it's all the flex lines on the car, not just the 2 front ones that most kits generally supply. The website is very thorough (for the commodores anyway).
  6. Cava454
    Cava454 Member
    Box
    VR SS, VZ SS
    Do you make custom lines mate?
    Ie: to relocate the abs and use braided lines instead of hard drawn.
  7. braidguy
    braidguy Member
    The price is $255.00 for VR-VS (live-axle) 5 lines kit, with VT front calipers mod. For VR-VS (with IRS) 6 lines kit, the price is $265.00 for the same VT front calipers mod. Delivery is included.
  8. braidguy
    braidguy Member
    The price is $255.00 for VR-VS (live-axle) 5 lines kit, suit C4 front calipers mod. For VR-VS (with IRS) 6 lines kit, the price is $269.00 for the same C4 front calipers mod. Delivery is included
  9. braidguy
    braidguy Member
    Yes mate, we do make custom-lines. Just give me measurement, and drawing with fittings to use and I am able to give you a quote. Email me: safebrake@hotmail.com
  10. immortality
    Sth Auck, NZ
    Hi mate,
    You have a PM
  11. braidguy
    braidguy Member
    Replied your PM mate.
    Thanks.
  12. scvs6
    scvs6 BLOWN VS BERLINA
    Tamborine Mountain, QLD
    '10 Holden VE SSV Wagon
    Any chance you have made front brake lines to suit a VS with VE front Brake Calipers and 322mm discs? Don't need the rear because I have already installed them and using the standard VS Calipers, but not sure if I can use the front brake lines that came in the kit.
  13. Allenriddoch
    Allenriddoch New Member
    Australia
    Nissan 300 zx
    SAFE BRAKES is really a good option to go with , as brakes are one of the safety device on your car. if you are looking for break specialist which can install SAFE BRAKES in your car then you may contact brake repairs thomastown , after getting them install by proffessionals you would experience new change in your driving, you never had before
  14. VP-57-TT
    VP-57-TT Member
    Guildford
    vp executive series 2
    how much for braided lines to suit VP live axle ABS with VY front calipers
  15. braidguy
    braidguy Member
    Hi mate,
    Please PM me for price.
