you starter motor will last hhhmmmm,.... alot less! an at $150+ for a reco is it worth it? and you wouldnt turn the car right off cuz the fuel system would cold start prime itself again (go from 36PSI to 45+PSI) you know that 3 sec buzz u get when u hit the key before u start the motor of a morning (thats why your car uses more fuel to start, well that and the CTS sayn "i`m cold walm me up"..... and not to mention you O2 sensor cooling,... thats why holden put heaters in them,... cuz they dont work when they are cold. switch off would start the cooling off process and throw you light throttle and idle fuel consumption off till it walms up again. PUT IT IN "N" if your that worried but as all the other wise driver suggest WATCH YOU MIRRORS FOR IDIOTS!
