Shocks and struts for FE2
Discussion in 'GSL RallySport' started by Scooter79, Jan 28, 2010.
  1. Scooter79
    Scooter79 New Member
    South Coast, NSW
    VSII Calais supercharged
    I just picked up some FE2 springs to replace the original standard ones. The FE2 springs I got are from a V6.
    I was wondering whats shocks and struts I should be using with FE2 springs considering FE2 isn't really a 'low' spring. If I went with Lowered KYB's is there a possibility they could be too low for the spring or should I just use standard height struts and shocks?
    Cheers.
  2. centy
    centy New Member
    Vp series 2
    It is a factory option so shocks are very easy to get.
    there are listed right beside standard in the fitment books.
    Ie fe2 sports and police are all the same shock.
    yes v5w uses the same shocky as fe2
  3. Scooter79
    South Coast, NSW
    Had some time this morning to give Holden spare parts a call and they confirmed that FE2 had different shocks and struts to suit the springs. They also confirmed that rear FE2 (IRS) shocks were $130 each and front fe2 struts are no longer available.
  4. jazza15
    jazza15 Jarryd
    Eltham North, VIC
    1999 VT II S
    Gee, a lot changes in a couple of weeks.
    I just bought a pair of front Fe2 shocks from Holden at $130 each the other week.
    The rears I got in 'as new' conditionfrom a place that sells parts taken off cars when they are uprgaded to HSV spec (new).
    V8's and V6's as well as the sedan, wagon (and i think ute) variants all have different springs with different spring rates etc.
    Between the Ford Falcon and Territory, there are around 10 different types of springs that go into the various models.
    Suspesion is model specific.
  5. danja
    danja Swerves for gay koalas
    CBF 250 and a Levin ZR
    Why not just use FE2 shocks with FE2 springs? Will probably be cheaper too.
  6. Scooter79
    South Coast, NSW
    Jazza15, you're talking about VT which are still available through Holden and online as you said.
    Isn't that what I'm talking about? Bit hard to do if Hoden no longer make FE2 VS struts.
  7. danja
    Sorry I thought you were talking about switching to KYB, didn't realise Holden production had ceased.
    KYB low should be about right. I tried super-low in my VZ with FE2 springs and they were a bit too short and could bottom out at extremes. With low you should be about on-par with FE2.
    KYB have a good phone support line, you can talk directly to their engineers who should be able to answer any questions you have. Suggest giving them a call.
  8. Scooter79
    South Coast, NSW
    I downloaded the Monroe catalogue to compare and the Sensatracs and GT Gas (not the GT Sport) have different part numbers for front standard and FE2 but the rears are the same shock for FE2 and standard.
    Don't you mean you tried super low springs with FE2 shocks? If thats the case I can understand how it could bottom out but my theory is with shocks that are designed to suit super low springs, but fitted to a car with FE2 springs, would not be allowed to fully extend. Kind of the opposite of bottoming out.
  9. gslrallysport
    gslrallysport Active Member
    VZ AWD One Tonner
    Hi mate,
    Sorry about the late reply! We were closed Thurs/Fri for stocktake, and I'm trying to catch up on all the emails now rather than be swamped tomorrow!
    KYB do a specific shock for FE2. The 'lowered' one you're thinking of is the new 50mm shortened shock for superlow and lower, but they do one between that and standard for FE2 or low springs.
    They're $140 each for the front, and $69 each for the rears.
    Regards,
    Greg
  10. danja
    Nope, FE2 springs and SL shocks. Yes the shocks were too short and "reverse bottom-out" (whatever that's called).
  11. anarklov3r
    anarklov3r New Member
    2007 WM Caprice
    What would happen if i were to swap out the springs in my stock standard VXII with some FE2 springs from a VX? Would i 'need' to swap out my shocks?
  12. gslrallysport
    VZ AWD One Tonner
    Wouldn't need to as far as being captive is concerned, but if they're the original already flogged out struts in the car, matching them with slightly hard springs is going to throw the handling out the window.
  13. anarklov3r
    2007 WM Caprice
    The struts are stock spec ones, but are Monroe GTS or something like that and have been replaced prior to me buying the car. Ive got a mate thats replaced his FE2 springs with some SSL's and SL's and wanted to slap his into my car :)
  14. gslrallysport
    VZ AWD One Tonner
    Yep, FE2 will be fine then. Monroe aren't the best shock getting around, but provide they're in decent condition they'll be fine!
