greenacc
Searching for the billion
- Jul 13, 2008
- 6,898
- 3,071
- 113
- Location
- Sydney
- VE Berlina
I see what you mean that cap on the spring doesn't look cantered. Is it loose, can you move it side to side more than the others?
Well at least all the rockers are rocking that's a good start.
Does it look like oil is flowing up to the rockers? The pushrods should be hollow and from memory oil flows up the pushrods to the rocker at the top?
If you wish you can undo the 'bridge' piece on top of that funny valve, another 2 bolts, and have a look at it. Best to do that while both valves are closed so no pressure on the rockers and nothing will jump out... Rotate engine by hand until valves are closed.
Don't know how that will help though.
Nice vid too mate.
Very hard to say if those rockers are rocking as much as they should or not ( that would determine if there's any issue with the lifters)
Does car have good power when you give it some? That would suggest valves are opening ok too.
Ever services the transmission ?
Nice vid too mate.
