Jimmy SV6
Colours Wow, Now It Glows
- Apr 1, 2009
- 112
- 1
- 0
- Age
- 39
- Location
- Hornsby, Sydney
- [Black] 05 VZ SV6 [Auto]
I strongly suggest you listen to that sub before buying it, you basically buying sony's very entry level sub, if you check the web or some other stores, you'll find the sub itself retails for less than $100, you have to ask yourself, at the end of the day, are you really going to be happy with your entry level sub, and your rear coaxials....? What type of MP3 player are you wanting to connect??There's better ways than having a USB port connected Via the front of the H/U, I'd strongly suggest you look around and have a listen to a few products, and avoid buying everything from the same manafactuer, your only limiting your options by doing that, and if have your budget to stick to, but still serious about your sound, i wouldnt be spending more on the head unit than any other compnent, you'd be better off spending $150 on the head unit, rather than $300, then having $350 to spend on your front speakers,rather than $200- also your doubling up on your rear fill speakers, also you will have 6 speakers, I.E 6 channels, but only a 4 channel amp, unless your planning on running your coaxials of the head unit, in this case they probably wouldnt even be heard over your 6x9's, basically making them a waste of $80...don't be fooled into thinking the merrier and the louder, you can get just one pair of speakers, which themselves would be more than capable of out powering all 3 sets of speakers you have listed here..
hmmm that is very interesting and now i want waste my $80 to get rear speaker in the doors
well my mp3 player is a Microsoft zune MP3 play that has a usb connection was wondering if it would connect to the deck... i would assume it would as it has a usb port on the deck
