Spigot Bush Question
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Chris E, May 21, 2009.
  1. Chris E
    Chris E New Member
    Vr Executive 3.8
    Hey all
    Currently in the process of converting my auto vr v6 to a manual because I'm sick of auto and it starting a fire was the last straw lol:ranting:.
    I'm not a mechanic and have only learnt what dad has taught me so bear with me lol.
    My question is to do with the the spigot in the crank, I got a manual spigot bush off the fellas at autobarn and it looks like it will fit nicely into the crank but I want to make doubly sure that this is how it works. I didn't have to remove anything from the crank when I took the auto box out.
    I'm thinking the manual spigot just goes straight in? looks like a nice snug fit but want to make 100% sure.
    Have attached a picture of the crank as it is at the moment.
  2. Chirpstr
    Chirpstr A new project attack
    VR Berlina M5, VP M5
    Your on the right track mate. Or you need to do is put that brass metal spigot in with a little bit of grease. Use a socket and a hammer to get it in.
  3. Radarboy
    Radarboy New Member
    VS Commodore
    The crank weather it's and auto or manual are the same. Tap the bush in with the correct tool if you have one for bushes. If not gently do it with an extension bar. A bit of locktight can be rubbed on the outside of the bush for piece of mind but is not really necessary. I small dob of grease on the end of your finger can be rubbed inside the bush. Don't put to much grease in there and get carried away as you don't want grease on the clutch face.
    The important thing is to tap the bush in evenly ie..top/bottom/left side/right side....slowly millimetre by millimetre. If you don't put it in straight you will have trouble when your trying to line the box up when fitting.
    have fun hope your doing this on a houst but I guess your doing in the garage on your back LOL.
  4. clubby_you
    clubby_you New Member
    brisbane
    vs clubsport
    word of warning don't use grease on a brass spigot bearing they are made of a porous brass and have tiny pockets of oil in them to self lubricate.
    If you put grease on it sometimes it will burn and start to sqeal just use a little bit of engine oil is all you need.
  5. Radarboy
    Radarboy New Member
    VS Commodore
    Clubby you.
    ..I haven't heard that before. What do you think of a small bit of copper grease. I just don't like the idea of leaving them dry.
  6. Chirpstr
    I've never had a problem with mine. I think you guys have a different spigot being a vs.
  7. clubby_you
    brisbane
    vs clubsport
    i just use a bit of engine oil is fine until it starts self lubricating
  8. Chris E
    Chris E New Member
    Vr Executive 3.8
    Thanks for your quick replies guys should be all sweet now.
    And Radarboy Yep i'm doing it in the shed on my back lol.
    Tapping it in with a socket thats the same method as the bearing on the my sigmas flywheel then, to easy.
    Can't wait to be 5 speed :yeah:
  9. delcowizzid
    delcowizzid on holiday
    NZ
    в∞ѕтεכ √&
    its silicon bronze and wont need any lube as said above its in the material its made of
  10. maldotcom2
    maldotcom2 New Member
    Cammed mafless VS Calais 5-speed.
    Everywhere i read said to lubricate the bush. I just used some high temp L80 grease.
  11. social
    social Ute Finatic
    South Aus
    MY06 6.0L VZ Thunder(na naa na naa..)
    the type of metal the bush is means it will pull in the oil (which is the point of lubricating) and when it gets how it will "sweat the oil" which makes for a good lubricant during use..
  12. kniever
    kniever Active Member
    greensy, melb
    VY II Calais L67 & VN II Calais T5 5ltr
    when i did my conversion i left the spigot bush soak in a tub of fresh tranny fluid for a couple of days and it went in nice and easy and ive never had trouble
  13. Reaper
    VZ LX8 Adventra, VP SS
    I have always put just an ever so slight smear of high temp grease on the spigot bush and tapped it in with the handle end of a hammer (or at the very least cushion it with a piece of wood). Don't go metal on metal as the bush is very soft and will damage easily.
    Reaper
  14. vscom88
    vscom88 Andrew-
    VH Commodore
    Late reply i know, but is it trans oil that is used to lubricate the bush ?
  15. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    I wouldn't use trans oil as it's too thin - use HT grease like Reaper suggests...just a touch. In theory they come prelubricated unlike the old days where you had to soak them overnight.
  16. UW1SH
    UW1SH New Member
    Awesome thread i was just about to post the exact same thread about whether the bush is suppose to fit in there nicely or if its gotter be tapped in.. I put a new spigot bush in my ecotec tonight and had to tap it in cause it woulnt just slide in.. I guess i got my answer. I used high temp wheel bearing grease is this ok??
    P.S Thanks Chris E saved me doing it.. :)
  17. markovr
    markovr Well-Known Member
    northside brisbane
    94vr 5sp .04vz wgn,93vp wgn,82 vhV6 wgn ,88 vn 5sp
    If you buy the bush from holden it will be in a plastic bag that has a smear of oil all over the inside from touching the bearing but whatever is used as long as it is a lubricant it will be ok...I also soaked the last one overnight in oil to make sure......the only drama I had with the spigot was that the 2 times that I have replaced my clutch the spigot bearing has spun in the crank and was loose and it came out with my hands...so the last time I loctited it in
  18. UW1SH
    UW1SH New Member
    i got my from bursons auto parts and it came in a little packet with tiny bit of oil in it.. oh ok awesome so i made a good decision to jam it in there with a hammer.. thought i was being a little dodgey haha
