before you do some change, diagnose first to see what are the codes to be fix first, if thers only abs and traction codes, check battery voltage, if greater than 16.5volts it was weak battery or alternator overcharging, if it have engine codes, fix the engine problem, abs and traction will appear if engine have codes, dont do any abs related issue if abs codes is C0561....
