T5 on a 253
Discussion in 'VB - VK Holden Commodore (1978 - 1985)' started by IhateRICE!, Jan 29, 2008.
  1. IhateRICE!
    IhateRICE! New Member
    VNSS Atlas Grey
    just want to ask if an T5 ( VN manual Gearbox) will bolt straight on to a 253?
  2. Tom_1569
    Tom_1569 Ecotech Power
    Gippsland - VIC
    '14 SR5 Pusslux
    dont think so, you can get adapter kits, from CRS and Dellows.
  3. IhateRICE!
    VNSS Atlas Grey
    how sure are you on this??
  4. Tom_1569
    Gippsland - VIC
    '14 SR5 Pusslux
    Not 100% mate, but i THINK they are, i remember reading, that you can get conversion kits.
  5. SL/ENUT
    SL/ENUT The SL/E Fanatic!
    Burnie, Tasmania
    VB SL/E 5L and VC SL/E 3.3L
    The 253 are an aussie bolt pattern block, the T5 all have a turbo bolt pattern bellhousing so, yep you need an adapter plate from either CRS or Dellow, but remember, this will make the shifter sit back to far, you need to make some mods around the gearbox hole.
  6. Reaper
    VZ LX8 Adventra, VP SS
    There is also the option of plugging and re-drilling 2 holes at the back of the engine block. Dellow may do an alternate bell housing which also would be fine. I have never liked the adapter plates that fit between the block and existing bell housing though.
    Reaper
  7. Swordsy
    Swordsy mmmm beer....
    Newi NSW
    VUII Maloo R8 - HX Tonner - XJR1200 - XR450R
    Full new belhousing from CRS or Dellow, did look a a similar thing before (turbo to aussie, just opposite) New belhousing was only going to be about $400 or so. can't quite remember.
    Have a look at the CRS cat online and email for a quote. Or give em a call and they'll tell you exactly what needs to be done and the cost.
