Tech2 OBD II Software
Discussion in 'VY Holden Commodore (2002 - 2004)' started by adamdunford86, Jul 10, 2011.
  1. adamdunford86
    adamdunford86 New Member
    Perth, WA
    2002 VY Commodore 3.8 (Dual Fuel)
    Hi Guys
    I want to active the police mode on my 2002 VY commodore. Plus look up any error codes and have a general nose round the setup of the ECU
    I have the Tech2 OBD II cable for my computer, i have located the ECU socket under the steering wheel
    But not sure what software to download and use to do this? I have had a look at EFILive v4 but couldnt get it going.
    Any ideas would be great as i dont really want to go down and hassle the dealer.
    Thanks
    Adam
  2. Fletch_QLD
    Fletch_QLD New Member
    Brisbane Bayside
    Sold my L67 VY S2 Calais :(
    V6 needs OBD I (ALDL) not OBD II I thought ?
  3. brodster
    brodster New Member
    Frankston
    vn hsv wagon
    Mate waste of time playing with comp as it dont make it go any faster unless you work engine,do an engine conversion to a supercharged v6
  4. Fletch_QLD
    Brisbane Bayside
    It's not about making it go harder, or sounding beast, it's about poking around.
  5. PRAVX II S
    PRAVX II S Member
    Australia
    Commodore
    Yes you are right mate.
    From vz onwards its protocol is OBD II.
    To the op you need to make the OBD cable it uses OBD II connector but talks OBD I.
  6. adamdunford86
    Perth, WA
    Hi guys
    Thanks for the reply, im not interested in making the car faster, but enabling the police mode to get a permanent digital speedo, and also looking at any error codes the car has or may get in the future, will also be interesting to have a look at the other settings in there.
    So my Tech2 OBDII cable is no good for the VY 02?
    Thanks
    Adam
  7. Fletch_QLD
    Brisbane Bayside
    That is correct - (no good for VY V6). Also, I don't think police mode is DIY possible, consumer OBD tools can only read info.
  8. one_and_only2004
    one_and_only2004 Turbo L98 FTW
    Regional NSW Australia
    Z Series Thunder Utility - Turbo
    Yep, you either need to see Holden and get them to enable police mode, or phreddy from ASR can do it too. My Holden dealer did it for free.
  9. chargedvx6
    chargedvx6 New Member
    VY SII HBD Calais L67
    The OBDII plug is the same as an OBDI plug (what your car needs), it's just the language/ speed the tech talks to your car in is different.
    Go with the cable and find the correct software to talk 8192BAUD. Send me a pm and I'll link you up
  10. one_and_only2004
    OBD 1 and 2 cables have different circuitry - it's not just a matter of changing software.
  11. Fletch_QLD
    Brisbane Bayside
    So OBD II plug can be used if you have the correct software? What about OBD II bluetooth devices?
  12. WELSHH
    WELSHH New Member
    2008 VE 6lt SS Ute
    so other then give u a digital speedo, what does police mode actually do?
  13. DLFHUB666
    DLFHUB666 GIT 'EERRR DONE!!!
    Nhulunbuy NT
    VX SS, PX Ford Ranger XLS Dual cab
    Xtra 50 rwkw bro :driving: But seriously nothing.
  14. PRAVX II S
    PRAVX II S Member
    Australia
    Commodore
    Here is some info mate on the GM 8192 check the link out.
    Can be made up your self just need some electronic and soldering know how.
    GM 8192/160 Baud ALDL Interface
  15. WELSHH
    WELSHH New Member
    2008 VE 6lt SS Ute
    does it really or u just having me on?:surprise:
  16. DLFHUB666
    Nhulunbuy NT
    Only if you have sirens an lights hooked up aswell.:cops:
  17. kcpwns
    kcpwns Kicker - Livin' Loud :)
    Shepparton
    VY V6 Equipe
  18. WELSHH
    WELSHH New Member
    2008 VE 6lt SS Ute
    well that stupid! who ever decided to call it police mode is even dumber then me, it should be called "you got conned into feeling like a cop with your digital speedo mode"
  19. one_and_only2004
    It also disables the stereo volume and radio stations coming up on the speedo screen.
    And the digital speedo comes up by default on the screen regardless of what it was on before you turned the car off.
  20. Antsmash
    Antsmash New Member
    Auckland, New Zealand
    VY SS Black
    It also enables you to "Trap Speed", and recall that trapped speed at a later time.
    You need a Tech2 programming computer. I'm pretty sure a cable and software will only let you read the data. I may be wrong.
