TH700R4 V6 & V8 Differences
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by CalaisJohn, Oct 3, 2009.
  1. CalaisJohn
    CalaisJohn New Member
    Melbourne West
    VN Calais S2
    Thought I'd start a thread on the differences between V6 & V8 model trannies as V6 trannies are plentiful and fairly cheap to source, as opposed to the V8 tranny. Apart from the obvious bell-housing & input shaft difference's i'm asking anyone in the know if the internals are same ? ... for the many of us with tender V8 auto's and some bush-mechanic skills could we transplant any V6 components and keep our rides rolling that little bit longer? any knowledge welcome :)
  2. Morton
    Morton For external use only
    Fairstar the Funship
    I dare say it would be possible. I'm not aware of different part numbers for trans service kits or shift kits for either model. So the valve body must be very similar if not identical. I'm not sure if the V8s run stronger clutches, but I doubt it given how fast a 304 can destroy an old T700. I'm also fairly confident that the servo setup would be identical.
    As far as I know the gear ratios are the same too, so the only differences that I'm aware of are in the physical size of the shell and bellhousing, and the size of the torque converter.
  3. greenfoam
    greenfoam New Member
    VP Executive R-spec
    Same gearbox as far as I know (apart from front section of the case)
  4. CalaisJohn
    Melbourne West
    VN Calais S2
    thanks for your input guys so far it sounds promising :)
    I'll let this thread gather some info then i'll get the tools and camera out :p
  5. padrickz88
    padrickz88 Rick =]
    sunshine, melbourne
    VN V6, nothing special
    i always thought the difference between the v6 + v8 gearbox's where the input shafts? maybe longer or different amount of splines something? (im just guessing)
    I could be wrong and most likely am, i remember seeing something about it ageeeeeeees ago so dont know how true it is
  6. greenfoam
    VP Executive R-spec
    The shafts would be different lengths? but the insides should be the same
  7. burnz
    burnz dah dut dut da dah
    springfield
    2010 CRUZE Diesel
    usualy the only differance is ratio not strength. (first/second) gear is taller.
    this applies to 2 speed power glide, is 1st gear is taller in V8 thats the only differance.
  8. padrickz88
    padrickz88 Rick =]
    sunshine, melbourne
    yeah pretty much what i was thinking but like i said, i could be wrong lol
  9. CalaisJohn
    Melbourne West
    VN Calais S2
    well for the price of a reco tranny I aim to find out lol
  10. greenfoam
    VP Executive R-spec
  11. CalaisJohn
    Melbourne West
    VN Calais S2
    thnx greenfoam. Definately the most difficult will be learning all the components and their function.. nonetheless I'll plod along and chew like crazy.
    I have the necessary donor V6 auto's (two in fact) and as I accumulate some knowledge will begin stripping one down. Anyone out there with a shagged V8 T700 willing to donate would be great. Otherwise i'll see what the wreckers have on offer.
