The "Ask a plasterer" thread.
Drawnnite
Obviously Unsensible
2000 Vs Ute
so I was going to be smart and ask you to come fix a hole in the wall ;)
but then this came to me.
you know how you can see the plaster joins in walls and ceilings, and after a while they show a line or a crack, or a very noticeable.
is there any way to prevent that in the first place?
if not what is the best way to repair it, preferably so it doesn't happen again?
oh and why do you guys chuck sparkies cables anywhere after they have been set up nicely.
or plaster sheet the sides of the wall that said sparkies don't need to get cables out of first :thumbsup:
AirStrike
91' VN SS
Question, how do you guys do such **** work making life hard for us painters :p
Dayvo
Because i can
67
South East,Victoria
VE SV6 Series 2
Wow , This threads off to a good start :spot on: . My son is a sparky and he said the same as Drawnnite
commodore665
expat Saffa
54
New Zealand via Cape Town
2005 SV6 & Alfa Romeo 156 V6
Funny that , my nephew says the same thing , he's a electrician as well
rory
Donating Member
Western Australia
2014 VF SV6 & 2006 Nissan Patrol ST
I have a 70's house that has had water through the ceiling at some stage, the affected area is about 500mm x 500mm and the plaster I guess has separated from the supporting thread looking stuff that should be inside and not visible, should I fill it with filler or cut it out and replace the section and if I get someone to replace the ceiling section (or the entire rooms ceiling) what sort of price am I looking at?
Trayner
Fresh prince of Pakky, Gangsta
Gangsta Hundy
Depends on how old the house is , most modern houses wont crack for 10-15 years if they are properly back blocked and such .
And its cos most of the time they will pull there cables out right in the middle of a join where we have to run the boxes over to fill the joins lol.
Trayner
Gangsta Hundy
would probly be better to cut it out and replace with new sheet , and re trowel for piece of mind, and roughly 2 hours work . so around $100-200
VS 5.0
So that would be $600 in Perth money.
