The Silver Fox - another raptor charged utility.
Discussion in 'Raptor Superchargers' started by one_and_only2004, May 17, 2010.
  1. one_and_only2004
    one_and_only2004 Turbo L98 FTW
    Regional NSW Australia
    Z Series Thunder Utility - Turbo
    Thought I'd best show off one of the newer members of the Raptor Forced Induction family.
    Powa!
    CAI
    Pod Filter
    Mace 69mm Air flow sensor
    Mace 69mm Throttle body
    Mace 12mm manifold insulator
    Mace 12mm plenum spacer
    Jack Bros. Engineering heads
    Raptor 10psi Intercooled Supercharger (Intercooling thanks to Raptor Charged VX)
    Comp Cams Stage 2 Supercharged CAM
    Yella Terra 1.8 Ratio Roller Rockers
    Redback extractors
    Twin HM 2.5" High-flow Cats
    Twin 2.5" Manta Maloo Exhaust
    Mal Wood 400kw Tremec 5 Speed gearbox
    NPC cushioned button clutch
    Intercooled, Charged and Cammed it runs 237.1RWKW with 490NM of torque.
    I've pretty much done everything short of stroking the motor - which I'm not too keen on. Any ideas for more power are welcomed. Also a information on a straight drop in performance fuel pump would be appreciated.
  2. Raptor Charged VX
    Raptor Charged VX Turboed Ls1 FTW
    VY SS
    about time this thread is in here ..
  3. one_and_only2004
    I did it this morning - just for you Trent. Did you have any plans for changing the intake pipe?
  4. immortality
    immortality Donating Member
    Sth Auck, NZ
    Raptor does a 4" intake which should help a bit. enclosing the POD will also help. when you fit the cooler, move the MAF so it's after the cooler and the BOV. i figure that cam will really wake it up, especially with some ace heads
  5. one_and_only2004
    Yeah I might have to see about one of these 4" intakes. As for the pod filter I'm waiting on the intercooler to go in before I have a box built up - I'm going to make a mock-up box out of cardboard, Then get it made up out of a mixture of gal sheets and heat shielding.
    As for the MAF, I'll let RCVX work out all that business - I'll just drive the thing...
  6. Raptor Charged VX
    VY SS
    the maf is gettin located in the perfect position,, its up to you julian we can use four inch flexi pipe
  7. one_and_only2004
    Sounds like a plan actually, I'll see if i can find anything at work.
  8. Raptor Charged VX
    VY SS
    ok an we can reduce back to 3 inch onto the charger..a flexi intake would be good then we can really make the pressure side of the pipework flow well
  9. hail storm
    hail storm New Member
    Look'n good Jspec :D
  10. one_and_only2004
  11. psivyv6
    psivyv6 New Member
    tasmania
    ve ss sportswagon!!!
    looks good mate
  12. one_and_only2004
    Still haven't got my charger back - tim is sending it tomorrow - will be cutting it very close for this weekend!
  13. psivyv6
    psivyv6 New Member
    tasmania
    fingers crossed mate
  14. Raptorsc
    Raptorsc RAPTR6
    Cairns Qld Australia
    Hilux 4.0 V6 SC 400kw
    In the mail as they say
  15. one_and_only2004
    Was just about to update this - good news!
    My cam should be here by the end of the week, though it won't be going in for about a month now - unexpected holidays to Tasmania tend to wreck the budget...
    Also had a talk to ChipTorque in Nerang about getting a MAFless tune - $1400 drive in/out including all wiring and sensors - very tempting.
  16. Raptorsc
    Raptorsc RAPTR6
    Wonder what the progress on this one is .............
  17. Raptorsc
    Raptorsc RAPTR6
    Tick tick tick .......... must be some new info soon or maybe its just the long drive back
  18. one_and_only2004
    Righto, just got home!
    Put the supercharger on Friday morning - the annoying noise was gone for a while - until the idler pulley gave way too. $30.99 at Repco had me going again. Showed up at RCVX's place and started work on the intercooler kit.
    Everything fits perfectly - except for the front bar, but I'll grind that down a bit next weekend. The SSQV valve is a little bit small so I'll be looking for something a bit bigger over the next week.
    Had a bit of a problem with the electronic boost gauge. The brand is ProSport from America. For some reason it stopped the blow off valves from closing so all of my boost was being vented constantly. After that was fixed i took it for a strap and HOLY SHIT does it have some poke now! Can't wait to get 12psi happening. I also have to re-do some of the silicon joins as a few blew out tonight when i was having some fun...
    I'll get some more pictures of the whole setup tomorrow when it's not 2 degrees outside...
  19. Lazza78
    Lazza78 Banned
    SE bris
    VT HBD LS1, VL calais project
    nice ute there julian.. was good to meet ya over the weekend while 'the fox' was under construction lol
  20. Raptor Charged VX
    VY SS
    so you blew out some silicone mate,, maybe go for some bigger clamps. im guessing the system isnt loosing much boost,, you will have to let me know what the gauge reads when you put it on ..
    was a pretty good job on the overall , no real big problems,
