timing belt marks?
Discussion in 'VL Holden Commodore (1986 - 1988)' started by asht12341234, Oct 20, 2011.
  1. asht12341234
    asht12341234 New Member
    vs commodore
    Just wondering if anyone can tell me where my cam and crank should be sitting when i put my timing belt back on. I rushed into it and pulled it off now i have no idea how to put it back on.
  2. detox_nath83
    detox_nath83 Another VL Driver
    Queensland(Sunny Coast)
    VL Turbo Commo
  3. asht12341234
    vs commodore
  4. detox_nath83
    VL Turbo Commo
    im not at home otherwise i would have scanned the page for u with the instructions for the tension-er adjustment
  5. Vlt_Calais
    Vlt_Calais New Member
    Sydney-west
    Vl Calais Turbo, Vn Calais 5L
    let's just call it a save, that you asked first because the mistake has been made way too many times over the years.
  6. asht12341234
    vs commodore
    Well i wouldn't of tried to put it back on without knowing the correct way. thanks again detox_nath my car is running great.
  7. detox_nath83
    VL Turbo Commo
  8. 88-SERIES200
    88-SERIES200 New Member
    rb30det VL wagon project, VL series 200
    also make sure your number 1 piston is at (tdc) top dead centre because the cranks gear (bottom gear) will have say 12 teeth on it and the cam gear will have say 24 (twice as many teeth as crank gear) this means that when the crank turns the timing belt which turns the cam gear it will take 2 rotations of the crank to turn the cam a complete 360 degrees . So make sure you get that right. google how to safely check for TDC.one way would be taking out the no. 1 spark plug, disconnect the plug to coil and remove the fuel pump fuse and then crank the engine for only a second or two. in the plug hole tightly stuff in a piece of clean rag with some oil on it so that when you crank it the compression will spit the rag out when the piston hit TDC. then you will know your close and can look at where your dot is on the cam gear. hope that helps.
