Tips on removing engine and transmission
Shounak
The Kicking Horse
37
VX Executive S2 + XF Panel Van Project
I need to remove the engine and transmission from the ole project car.
Can I remove these together as one big part? My initial plan was to drop the tranny from the bottom, wheel it out and then take out the engine using the crane.
But apparently it's much easier to remove them both together using the engine hoist.
After disconnecting the tailshaft and all the appropriate engine connections (hoses, lines, etc), is there anything else I need to be aware of?
Do I need to take off the bonnet? How should I have my helper help me whilst I'm jacking the thing up?
Anything else? I haven't attempted anything of this scale before and neither has my friend. So any advice at all would be appreciated.
Morton
For external use only
Fairstar the Funship
Yeah, you'll need to take the bonnet off to get the crane in over the engine at the right angle. It's also a good idea to have at least two people there if you intend on taking the engine + trans out as one piece. When I did an engine + trans swap on an old VN, we had four people working on it solid to get the stuff swapped over in time. It's a little bit of a pain to get the whole assembly back in straight on the engine mounts, but yeah... removal, not too big a jig.
Shounak
The Kicking Horse
37
Cheers Morton,
Has anyone used an engine lift plate before? The X-Flow XF has a 2 barrell carb and it seems much easier to put a lift plate in, than the other options.
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
Ey man, if you need a spare set of hands give me a yell
Morton
I assume you just intent to bolt the lift plate onto the intake, shounak? It's a good idea if the lift plate fits perfectly... and if you think the intake can support the weight of the engine AND gearbox.
