Towing Capacity
oswald800
VX Series 2 Berlina
Ive got a VX Berlina Series 2 i know it says it can tow 2.1 tonne
Im looking at buying a boat but the load will be around 1750
Will this have any problems with my car in the future as in excessive wear
Looking at upgrading to heavy duty springs and maybe shocks
Any help on towing something with this weight would be good
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
If you're within the weight of the towbar (should be a sticker on the inside of the B Pillar) then you'll be fine. Trans cooler could help depending how it goes. Just remember the boat could be alot heavier when you pull it out of the water.
oswald800
VX Series 2 Berlina
Oh yeah its a Auto but with my current boat i have i drive it like a manual
oswald800
VX Series 2 Berlina
Got told that when towing heavy load if you drive it like a manual than its easier on the trans ?
fdbag8
Karoonda sa
2006 VZ SS Thunder
Either way a trans cooler is highly recommended! I have cooked a trans towing a ski boat!
VS-THE-BEST
Queensland
97VS HSV CLUBSPORT
Yeh i use to tow a 10x6 box trailer with my VS, it had a Auto tranny cooler on it and still use to overheat, the trailer was only 750kg.
I towed a horse float the other week, it had one horse in it and my VS Acclaim was getting thrown around like a rag doll.
I got a 2100kg Haymen Reece bar fitted to it as well. Bugger that mate i would be crapping my pants towing a boat that heavy, what if you get on a steep ramp and the car cant hold the wait?? The boat will end up heavyer then that once you load her up with gear to.
oswald800
VX Series 2 Berlina
So why do they say they can tow2.1 tonne
The weight of the boat is fuel everything in it
The Recidivist
WARRAK
VX2 Executive Wagon
Why?
[10 chars]
I burnt out the gearbox of my Jag once trying to haul a trailer up a fairly steep mountain in Sth Africa. It was my first automatic and, not knowing any better, I simply left it in drive and allowed it to change up and down on it's own accord. When the vehicle was being repaired in Durban, I was advised that, if in future I decided to do something similar again, then it would be better to change the gears manually. If I remember correctly, the reason they gave was that, if the vehicle was driven as a manual, the hydraulic bands in the gearbox were locked together and couldn't slip against each other, which apparently is the case if the gearbox is allowed to change up and down of it's own accord.
