VYFORI
VEFORME
- May 18, 2005
- 105
- 1
- 0
- Age
- 45
- Location
- Sydney inner west
- VE Sedan
swaybars nothlane
Gday Everyone....
Right i get the picture avoid front if possible thanks for the feed back....
Since my ute sits on superlows Its pretty rock solid anyway.. it was manly for body roll stiffness.
That much labour intensive Motor Out !!! Crossmember too.. !! WOW the rear ???
Trying to achevie better turn in less body roll i think lol ....
My turn in is pretty good its the back that loses it for me i know its a ute sand bags over
axles in the rear they say but there has to be a better way...
I do like the oversteer but in the rain in ute its pretty hairy sometimes...
I was looking at a K-MAC Welcome to K-MAC, Camber Kits, Caster Kits, Springs, Swaybars.
Front '03VY - '06VZ part number 201811 for just a replacement bolt-on $295 adjustable $495 30mm
Rear part number 201821 replacement bolt-on $165 adjustable $395 16mm
Plus i will be getting the F/R enchancement kit aswell Nothlane !!
Have any of your people used K-MAC ?? Good Product ?? $$$ ???
What do you people have in your holdens ????
RIK..
You want to know what you're trying to achieve with swaybars, don't change the front/rear ratio just for the sake of it. Generally you increase front stiffness relative to rear to increase understeer (can actually be desirable in a some cases) and increase rear stiffness relative to front to increase oversteer. If you are happy with the handling balance, you can increase overall stiffness to reduce body roll, but there is such a thing as too stiff.
The front is a pain, you have to remove the front crossmember to get it out.
hence why i never bothered with the front one much - i enjoy the added oversteer.
it's a real pain in the arse to get under there. I know a fella who had to lift the motor out of his car just to swap it over.
Performance wise it'd probably be a good idea - the rear sway bar did wonders for oversteer.
Gday Everyone....
RIK..
