VYFORI
VEFORME
- May 18, 2005
- 105
- 1
- 0
- Age
- 45
- Location
- Sydney inner west
- VE Sedan
Nolathane VY Suspension Pictures
GDAY EVERYONE....
I have those photos now posted below.... Spent about $398 in these 4 parts.
I Have not installed them yet but ill show you before and after shots.
In the previous above posts i said that i wasnt going to get bushes yet and wait
until i reach 200,000km (Done 158,000 now...) but though why no ill get the bushes
now front and back.
Nolathane VY REAR IRS KIT
Nolathane VY REAR CONTROL ARM OUTER
Nolathane VY REAR SWAYBAR LINK
With the above parts i have set them out on the table... Notice they supply you with greese aswell....
IRS KIT...
Only Fit the new kit to the Inner Pivot Mount only on VS Series 2 Onwards.
Put it up on a hoist and remove rear wheels / Exhaust Hangers and support.
Diconnect the Swaybar from Control Arm assembly
Because i had to remove these parts is why i purached the other bushes aswell.
This is how you remove the parts to install kit.
As you can see from the picture you get
4x Urethane Bushes
2x Eccentric Crush Tubes
2x Bolts 50mm
2x Bolts 25mm
2x Lock Nuts
4x Spring washers
1x grease satchel
The alignment is obtained by turing the head of the bolt to gain the desired specs
Once you have reached the required amount use the Control Arm Bolt to lock.
Torque Specs on Control Arm Bolt are 95 to 105Nm
Wheel Align. Specs
Camber -1.5 +/- 0.5 Degree (each Wheel)
Toe +1mm +/- 0.2mm
Probably best to get a Lic. Mechanic or workshop to get the job done..
Your Comments and help is most welcome...
Next ill purchase the front and ill show you before and after pictures of my rear too.
Still not sure if im going to go coilovers or just pedders shocks.. ????
Its a ute so only coilover fronts...
But ill purchase the front bushes...
RIK.....
GDAY EVERYONE....
now front and back.
IRS KIT...
4x Urethane Bushes
2x Bolts 50mm
2x Bolts 25mm
2x Lock Nuts
4x Spring washers
1x grease satchel
Wheel Align. Specs
Toe +1mm +/- 0.2mm
RIK.....
