Awesome, cheers guys!!
My issue is more in the front of the speaker, from top of the basket to the door trim, as it's a weird tweeter setup. I've attached the specs so you can understand what I mean.
Also forgot to mention, this is for the rear doors, fronts should be fine hopefully... :s
Hey Troyziee, well I got around to putting the rear door trims back on today. And about now I should admit that I am blonde and it does catch me out sometimes. As it turns out the door handle doesn't leave huge amounts of room at the top screw. Not a major problem, but I used 16mm mdf which was too thick at that point. All I had to do was trim it down a little. Just thought you should be aware to watch out for this.
After taking that notch out at the top it all fitted nicely. I guess you can do the same, or if the speakers are too big maybe use some slightly thinner mdf.
