vk3800
- Jul 29, 2005
- 69
- 3
- 8
- Age
- 45
- Location
- Coffs Harbour NSW
- VX S Series 2
Due to the number of people wanting to know about V6 conversion to VB to VK's I creared the below.
Anyone with additional things, bits i've missed or better ways of doing this, let me know and i'll adjust the thread.
Below is a step by step process to converting a VB>VK from original motor to a VN>VS V6.
Note: This is based on a VK conversion and there are other ways of doing the coversion. Some of which are better than what is out line below and some are not. This is to be used as a guide only and individuals should always check with their local/ state authorities before comencing any work.
Step 1 – Research and parts
• Consult an engineer that will do the job. It always better to take to them first, then to do the job and have to change it afterwards.
• Buy a complete VN/VS Commodore. This will give you most if not all of the part that will be required form the job and works out cheaper in the long run and what you don’t use you can sell to the wreckers or call the scrap metal man.
• Get a wiring loom adaptor. This will allow you to basically plug the VN engine loom into the VK car loom. You can get this from V6 Conversion in Moore http://www.v6conversions.com.au/ . Alternatively you can do the wiring your self or get a similar adaptor from other similar outlets eg Castlemain Rod Shop.
• Get a new gear box cross member. You will need one for both the auto and manual gearboxes. You could make your own or you can get this from V6 Conversions as well.
• Get a new radiator. I use a V8 VH/VK one as it bolts in and the hoses line up. You can use the one from the donor car but modifications to the supports of the VB>VK will be required as the bottom outlet hose on the radiator is to low.
• If you car is a carbie, which it probably is, you will need to change the fuel tank and add a fuel line. The VN fits in, but to me the VL tank is easier, as I know that it won’t be a problem to fit. The fuel line you may be able to take from the VN car if not get one from a VB/VK.
Step 2 – Starting the project
• Remove VK engine and gear box. This includes the radiator, tail shaft etc
• Remove the VK engine frame and front suspension, will need to provide support to car at this point by means of car stand or similar.
• Remove EST computer. Found behind passengers kick panel
This will leave you with an empty engine bay.
At this point you should decide if you are going to want your VK engine bay look like a VN. If yes you’ll need to move, or provide a new, battery bay on the other side of the car. If you don’t move the battery, you will need to extend the power wire to the battery. The VN battery is located on the right not the left side of the car.
As most engineers these day a very strict on what they will past, it’s probably a good idea to shift the battery to the other side.
Now would also be the time to paint the engine bay if you want to.
Step 3 – the donor car.
• Remove engine, gear box and engine frame, including the front suspension from VN car
• Remove radiator bottles, fuse box, etc
• Keep donor car around until conversion is complete. You come back to the car for other parts later on.
Step 4 – the transfer.
• Bolt engine frame from VN into VB>VK. This bolts up exactly the same as the VK one did. Do your best to get it as straight as possible, eg no twist in it, as any twist will put your wheel alignment and tracking out, eg car will put to one side.
If you leave the engine frame and front suspension bolted together then you should be able to bolt the whole assemble into the VK in one go.
Edit 1: As discussed below, the VS suspension can be fitted to the VB>VK. But for practicality and cost of the conversion, it would be easier to use the VN suspension or use the VB>VK as they bolt up to the VN K-frame.
Step 5 – installation
• Fit VN computer and wiring
• Drop motor and gear box into the VK and bolt up.
• Modify your VN tail shaft to suite. On mine I had the end shortened and the VK end fitted so it would bolt up to the diff. The rest of the tail shaft will bolt into place.
• Change your fuel tank over to the VN or VL which ever way you go about it.
• Add the extra fuel line. Just open the clips that hold you current fuel line in and add the extra line and close the clips back up. This is needed as fuel injection has a return line to the tank for the fuel that doesn’t get used.
• Wire into VK electrics. This could be part of the wiring loom adaptor from V6 conversions, not sure as I had an auto elect’ do mine.
• Connect water hoses up. If you go with the VH/VK V8 radiator the VN V6 hose should fit. Don’t forget your heater hoses.
• Air intake. If you’ve move the battery to the other side, then the standard VN air box and pipes should fit in nicely. May need to drill some holes in the location of the old battery to fix the air box in. Engineers don’t like pods unless it’s enclosed.
• If you use an auto box, make sure you connect the speed sensor. If you don’t the car will shut down at about 45km/h as the computer thinks you doing 245km/p
• Connect speedo up. This can be down a couple of ways. They way that I did mine was to change the gearing on the end of it one from a Falcon. This only works as mine has the manual gear box. V6 conversions should be able to help if your using an auto.
• Connect your exhaust up. This is up to you. I use the VN one and had it modified to fit under the VK. You might want a complete custom exhaust.
I can’t remember much more, as it was a couple of year ago that I did mine. But there’s all the tiding up bits to do and get it engineered and blue slipped.
hope this is of help to thise that are concidering the conversion.
