VE SS on King springs?
Discussion in 'VE Holden Commodore (2006 - 2013)' started by [QW-11-KE], Mar 8, 2010.
  1. [QW-11-KE]
    [QW-11-KE] New Member
    Roselands, Sydney
    E CLUBSPORT R8
    Hey guys need to lower my ve ss and there's an add on eBay for monroe gt shocks struts with king springs for about $680.
    Now I got three options
    1st option: super low all around
    2nd option: super low front, ultra low rear
    3rd option: ultra low all around
    Can you guys help me with the best option for a nice riding height for the ss please as I got no clue about lowering a car?
    Thanks
    Nik
  2. Cocopopz
    Cocopopz New Member
    VE SS MY9.5, VL LS2
  3. [QW-11-KE]
    Roselands, Sydney
    E CLUBSPORT R8
    Ye but I want peoples opinion on which one of the three choices I should go for in particular Im thinking of goin for the ultra all around but scared it might scrape too much
  4. [QW-11-KE]
    Roselands, Sydney
    E CLUBSPORT R8
    Ps I got 19" ssv rims
  5. HSV085
    HSV085 Member
    16' SSV Redline
    There's a 15mm difference between the superlow & ultralow springs, i have the superlows on my ssv which lowered it 50mm(f) & 60mm(r) from standard fe2 spec. When i first had the superlows in mine i thought that it wasnt low enough but i dont regret it now as there's not alot of clearance between the front bar & most concrete parking pillars & curbs, also ive got a full twin 3inch exhaust & i find i can clear most speedhumps if i take it easy with just me in the car but if i have a full car load then i have f@# all chance(you could make it over if your exhaust is a twin 2.5inch).
  6. [QW-11-KE]
    Roselands, Sydney
    E CLUBSPORT R8
    Thanks for ur feedback mate I do have 2 1/2 inch exhaust. I'm actually leaning towards ultra low rear and superlow front to give the ve that level look u know
  7. Cocopopz
    Cocopopz New Member
    VE SS MY9.5, VL LS2
    I was thinking about this aswell. It would be good to see how it goes.
  8. Ozzie
    Ozzie JCCC Warrnambool
    Mount Gambier
    Ozzie'z Supercharged VY Calais
    VE SS Have 19's as standard yea?
    If so I would say SL's all round.
    SL front and UL rears is just screeming out TOOOL
    And UL all round will give you a better chance of a pretty yellow sticker.
  9. tomholzy
    tomholzy New Member
    VE SS II
    if you go any lower than ssl you will scrape on EVERYTHING on the front, but on the rear go as low as you can
  10. [QW-11-KE]
    Roselands, Sydney
    E CLUBSPORT R8
    so Ultra lows r lower than SSLs
    and SSLs r lower than SLs?
  11. Ozzie
    Mount Gambier
    SSL's are ultra lows. just in king spring terms.
  12. dakman
    dakman New Member
    newcastle
    ve ute 22's lowered hardlid
    if you go super lows i wouldnt put short shocks cause you dont really need them. if you only want a little lower go super lows.. want it slammed go ultra low and short shocks.
  13. tomholzy
    tomholzy New Member
    VE SS II
    i thought SL were lows, SSL were superlows and SSSL were ultralows...
  14. [QW-11-KE]
    Roselands, Sydney
    E CLUBSPORT R8
    thank u tomholzy ur right mate i just checked the king springs online catalogue....
    im goin for SSLs which r superlows all around with monroe shocks.....
    thanks every1 for ur input appreciate it
  15. dakman
    dakman New Member
    newcastle
    i thought it was
    sl- super lows
    ssl's super super lows
    sssl's super super super lows or also known as ultra lows
  16. [QW-11-KE]
    Roselands, Sydney
    E CLUBSPORT R8
    According to the catalogue king springs ssl = super lows. And sssl = ultra lows
  17. Cocopopz
    Cocopopz New Member
    VE SS MY9.5, VL LS2
    I sent a email to king springs
    I have a Holden VE SS MY9.5. I will be fitting a set of 20" wheel with 243/35/20 tyres. What springs do I need so the top of the tyre is level or close to the gaurd?
    I was told to use SSSL's this confused me a little until I relized these were Ultra Lows. I would like to know how correct this is. Only one way, try and learn.
    Whats the number in the front of the part number?
  18. dakman
    dakman New Member
    newcastle
    as quoted with those photos in the cars are ssl or super super lows.. hence the 2 s's
  19. dakman
    dakman New Member
    newcastle
    i'd go ultra lows if you want it to the top of the tyre and get shortened shocks. cause it will pretty much be sitting on the bumpstop with no travel
  20. HSV085
    HSV085 Member
    16' SSV Redline
    Ve's are different,
    SL = Fe2 spec
    SSL's = superlows
    SSSL's = Ultralows
