VE SS stability control turning itself off. Please help.
Discussion in 'VE Holden Commodore (2006 - 2013)' started by damirdagsy, Jul 6, 2013.
  1. damirdagsy
    damirdagsy New Member
    ve ssv
    Recently the stability control (ESP) in my VE SS 2007 has been turning itself off followed by the check engine light illuminating. I had it scanned and result was ABS fault. Hence the ABS module was replaced. Less than 50km later, Stabilty control(ESP) turned itself off again and check engine light illuminated once more. Has anyone out there had the same issue and what was the problem? Or is there a mechanic out there that has had experience with this problem that could direct me to the cause. Not sure i'm happy just to take it to the dealer as it is out of warranty and let them spend hour after hour investigating with no fault found and a massive bill at the end. Really appreciate any help/advise that you could give me to steer my mechanic in the right direction.
  2. Wheatley098
    Wheatley098 New Member
    Australia
    Commodore VE SS Sedan
    I took the battery off for like 5 mins, then put it back in, Help "Trip + Enter" and it fixed it, Holding just enter to enter Diagnostics mode seems to remove the check engine warning lol weird I know
  3. damirdagsy
    ve ssv
    thx wheatley098. Will give it a try.
  4. EnFoRcEr_001
    EnFoRcEr_001 Deano
    VE SV6 A5
    Have you recently changed tyres or suspension, different size wheels around the car also causes this problem. Any engine modifications?
  5. MYVESSV8
    MYVESSV8 Active Member
    Brisbane/GoldCoast
    VE 6LT M6
    low battery can cause issues like this, mine did, is it starting ok, new battery all good
    have you had any wheel work done, or any other work
  6. damirdagsy
    ve ssv
    Thx guys for taking the time to respond. Have found a bit more info through earlier posts. Seams to start ok. I don't fully understand how a slightly flattened battery would cause a fault once the engine is running. Isnt the battery continually being topped up with alternator?
    Just this morning I took all wheels off and checked ABS wiring points and everything visually seams ok. I did notice that front brake pads are well worn and will replace today. I will also take battery out and get checked tomorrow. Once again appreciate everyones help. If I take it to holden can I have the confidence that they will rectify problem?
  7. lmoengnr
    lmoengnr Member
    Sunbury Vic.
    MY12.5 Maloo R8 & MY12 Redline ute
    Is the original battery still fitted?
  8. damirdagsy
    ve ssv
    yep. So battery is 6 years old. I will get battery checked tomorrow.
  9. lmoengnr
    lmoengnr Member
    Sunbury Vic.
    Don't worry about getting it checked, just get a new one. You certainly got your money's worth out of the current one...........
  10. Ripper_017
    Ripper_017 New Member
    sydney
    VF SSV REDLINE
    i have the same prob with mine recently . which is annoying the crap out of me , because itll just beep several times on startup . i have the engine light on , esp off and abs light on aswell . weird thing is i was just driving and it randomly happened . i rest the battery for a while but didnt change anything . i might try that enter+trip held down and see if that does anything , i wouldnt take it to holden because they just piss in your ear and charge you $100 to hook it up to the obd2 .
  11. damirdagsy
    ve ssv
    will let you know ripper what happens when I replace the old battery with a new one. It is frustrating especially when the Mrs is carrying on all the time about the car and the costs associated with maintainace. Especially when my other car is an EF falcon that has done 400,000 km and has been to the mechanics 3 times in the last 10years. I've had
    the holden to the mechanics 4 times in the last month.
  12. EnFoRcEr_001
    EnFoRcEr_001 Deano
    VE SV6 A5
    If its the original battery, my money is it being at fault. These ve's have hussy fits when the battery isn't up to scratch.
  13. Ripper_017
    sydney
    VF SSV REDLINE
    battery wont change the problem . everyone always sais its the battery .
    truth be told few years back i had an automatic sv6 . did the same thing , esp off , etc only thing which is much worse then my manual SSV , is that in auto it goes into limp mode and will only allow you to go 30kms an hour or something stupid . car bascially doesnt even move . now i too replaced the orignal battery after the previous owner of 4 years . made no difference at all , just the same story . i even pulled out the maff sensor and cleaned it with carby cleaner. holden hooked it up and charged me over $100 , removed it for it to only come back on 10 mins later . This is my 3rd VE , and all 3 have spat stupid esp problems without fail . Im curious on the trip+enter procedure , as i would like to try it myself . its annoying getting in the car and having it beep several times on startup.
  14. Sean880
    Sean880 Member
    VIC / NSW
    2012 VE SV6 series 2 and 911 Porsche 997
    Wheel Speed Sensors
    I think you will find you will have a faulty wheel speed sensor or sensors and until you replace the faulty item I believe you will continue to have the ESP shut off and ABS issues.
    For some reason, I understand the rear wheel speed sensors seem to deteriorate more quickly than the fronts so I would start there. (If this was my car I would just replace both rear wheel speed sensors and test drive).
    (I very much doubt that merely replacing the battery is going to solve your problems).
  15. Ripper_017
    sydney
    VF SSV REDLINE
    got time to hook up to the obd2 today , my car was spitting these codes , C1234 & C1209 .. anyone shed some light on what i could possibly do to fix these codes , sensors replaced etc?
  16. RiCeY
    RiCeY F O R U M W A R R I O R
    Australia
    VZ SV8 6spd 5.7
    Neither of those codes are legit, it must be C0 _ _ _
  17. Ripper_017
    sydney
    VF SSV REDLINE
    hmm maybe the app i was using is crap . ill have to find something else to try so it shows in that format .
  18. bigdaddycool
    bigdaddycool Member
    Brisbane, Queensland
    2009 VE SS SILVER SEDAN
    It's a pretty common fault, most times it's only when the commodores are cold. Start the car for like 30 seconds, turn it off, let it sit for 10 seconds and start it again and usually that fixes it. It's to do with a start up check it does and I believe it's caused by the O2 Sensors/Cat Checks.
    I turned my cat checks off in the computer via HP Tuners which fixed the issue for me.....
  19. `Aleks
    `Aleks New Member
    Black SSV
    Hey mate, i own a 07 sv6 and had this issue my traction control would come on when the car was not on and wouldnt started because of this. it happened afew times ( turning the key and nothing happened ) turned my lights off and it started. the battery sortly after gave way and with the new replacement it has not happened since.
  20. Ripper_017
    sydney
    VF SSV REDLINE
    20130713_112233.jpg Update for those who have the ESP/ABS problem .
    iv pulled out all my abs sensors and cleaned them with thinners , most had a little bit of gunk . also as mentioned they seam to say it is the rear left sensor that is a common problem , this was the first sensor i managed to look at , and straight away a dead sign as to why i was having problems. hope this helps as it immediately turned my esp back on and abs off.
