VE Steering Wheel Removal - How To Take Off The Airbag
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Troy711, Jul 7, 2009.
  1. Troy711
    Troy711 Retired Old Fart
    Canberra, ACT
    2011 Mitsubishi Pajero GLS
    Alot of people have been asking how to remove the steering wheel on a VE.. so here is a bit of a guide on how to do it.
    Step 1:
    Locate and remove the airbag fuse (look in the passenger footwell). I like to switch the car to 'on' after I have pulled the fuse just to check that I have the right one. It will come up with 'Airbag Fault' if you have done it correctly. Some people say to remove one side of the battery too, that is entirely up to you.
    Step 2:
    Turn the steering wheel 90° left
    Step 3:
    Feel behind the steering wheel and locate a square hole (circled in red)
    Step 4:
    This is where it can get fiddly. Put a flat blade screw driver in the hole with the blade running horizontal (as shown by the red line in the previous picture).
    Basically you are trying to pull the retaining clip away from the airbag hooks. The clip system has been traced in red (on one side only) to give you a better idea of how it works. The green circles are the springs which hold both sides of the clip system together.
    This is a close up of one side of the clip.
    The screw driver blade will go behind the red circle and the two red arrows are where the airbag hook underneath. When you lever the screw driver upwards it will pull the clip across enough to 'pop' out one side of the airbag.
    Step 5:
    Turn the wheel 90° right and repeat. The airbag will now come off freely.
    Step 6:
    Unclip the blue and orange plugs that go to the airbag.
    Step 7 (for total removal of steering wheel):
    This is only going from memory (but it isn't too hard to work out what is going on).
    Unclip the white plug in the center of the steering wheel
    Step 8:
    Undo the big torx nut in the middle using a T45 torx bit and you are done.
    EDIT: I've been told a T50 works better but I haven't tried it myself.
    Like I said, it is very fiddly and might take some time to actually get the airbag off but once you know what you are doing and how the clip system works it is pretty easy. If you have any questions or if I haven't explained something properly here just post and I will try and answer them.
    NickVR likes this.
  2. NickVR
    NickVR New Member
    Adelaide, SA
    VR Executive A4 V8
    Well done. Great post, if we still had rep points you would one more right here.
  3. Troy711
    Canberra, ACT
    Cheers bloke :)
  4. DJ Ice
    DJ Ice New Member
    Gold Coast
    MY07 VE Calais V
    Nice work...two questions though when you undo the torx nut in the centre I assume you have to give the wheel a bash from behind to remove it like earlier Commodore wheels ? Did it take much force to remove ?
  5. davey g-force
    davey g-force I'm a sceptic...
    "...the winner is..."
    02 RX7 S8 Spirit R 13B TT & 2013 Audi A3 1.8T DSG7
    Awesome write-up Troy! :thumbsup:
    In the VY, turning the ignition on whilst the airbag fuse was pulled out was a big no no, as it would log an airbag fault which could only be cleared using a Tech2. Is this the case with the VE?
  6. Troy711
    Canberra, ACT
    Mine actually slipped pretty much right off. I think I may have given it a tiny wiggle side to side to get it going but it required bugger all effort.
  7. Troy711
    Canberra, ACT
    Good question... mine didn't show a fault and hasn't done yet. (Fingers crossed)
  8. redmick
    redmick New Member
    VE Calais VX Calais
    Great post thanks a lot i just bought a new Red hot wheel for my VE Calais and thanks to your post i had it fitted in 20 minutes the wheel itself was not a problem to pull off as it is on a parallel spline so once i undid the torx bolt it pulled straight off on it can only go back on in the same spot due to the design of the spline.I decided just to disconnect the battery rather than remove the fuse it was simple.The bigger the blade on the screwdriver the better as i just turned it but the screwdriver has to be short enough to fit behind the wheel with out being too long and the dash getting in the road.
    Redmick
  9. davey g-force
    Troy,
    I started doing this today, following your instructions but didn't get very far. I'm hoping you or someone else here could help out.
    Firstly, I couldn't find an airbag fuse in the passenger footwell in my car (SSV). I then checked the fuse box under the bonnet and found a 10A fuse marked "airbag" there. Thing is, when I pulled that fuse out and then turned the ignition on, I didn't get the "airbag fault" message. I didn't want to risk the airbag deploying, so thats as far as I got.
    Can anyone tell me exactly where the airbag fuse is on an SSV? If not, is it good enough to simply disconnect the battery? The problem is, I need to re-connect the battery half way through to turn the car on so I can turn the steering wheel 90°! Is that risky if the fuse is still in? :confused:
  10. andyman
    andyman The Only 6sp VZ Wagon
    Orange, NSW
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    id personally disconnect the battery, that way you know the car has lost all of the power, you are assured there will no mystery circuits that may still keep parts of the air bag system active,
    great write up there troy
  11. davey g-force
    Fair call.
    So, when I get half the airbag off and I need to re-connect the battery to start the car, to turn the wheel 90° the other way, is there a risk of the airbag going off?
  12. azkwazere
    azkwazere Ahhh Yes, Ahhh Yes....
    .....SE Burbs
    VP 5-SPD / 24-SPD Racer Hybrid
    Dont see why there would be, its not like your touching an airbag sensor or anything...
    aZk.
  13. Troy711
    Canberra, ACT
    I dare say the fuse would be the same across the board. Did you look on the underside of the panel and look at the fuse diagram?
  14. davey g-force
    Yeah, I checked the diagram on the back of the removable cover in the footwell. Unless I'm going blind, I definitely couldn't see anything relating to the airbag there.
  15. grayzpd
    grayzpd New Member
    ve berlina 3.6
    [quote removed to keep thread tidy]
    I'm gunna give it a go on the weekend ....looks tricky ....probably need to get in touch with you....thanks for your help
    grayzpd
  16. Troy711
    Canberra, ACT
    It's really not that hard.. when you work out what the lock mechanism does and how it works you will get it easy.
  17. davey g-force
    I never ended up getting it. I wrestled and cursed for three hours and then gave up. :bang:
  18. 08 ss
    08 ss New Member
    VE SS 6.0L
    Hello All
    New to the site. Found it while looking for info on changing steering wheel spokes. Just wandering............
    Is the t45 bolt a normal thread or reverse?? Tried to get it off and made a mess of it!!!!!!
    The torx part is rounded off now.
    Need some advice.
    Thanks.
  19. 08 ss
    08 ss New Member
    VE SS 6.0L
    Hello All
    FYI
    It is a normal thread ie anti-clockwise to loosen.
    Got it out - blue locktite made it really tight - need your muscles :hmmm:
    Happy Days. :yahoo::yahoo:
  20. CSP
    CSP Banned
    my car
    When I did mine (and susequently told Troy how to do it :p) I disconnected the battery instead of the fuse just to be sure... Easier to access and easier to do too.
