Ve V6 starting problem.
Discussion in 'VE Holden Commodore (2006 - 2013)' started by calais06, Dec 18, 2011.
  1. calais06
    calais06 Donating Member
    Sydney, NSW
    VE Calais MY06
    Hey all,
    Tried doing some searches but couldn't really find what I was after.
    I have a 06 ve v6 and over the last 2 days I've had a starting issue.
    One was when it was dead cold and when I went to start it tried cranking maybe 5 secs longer than normal and didn't start, so I turned the key off and tried again then it started right away..
    It was all fine for the rest of that day, and then the day after it did it at the petrol station when it was hot.. So its not temperature related, any ideas what it could be?
    The car has 108,000km on it, and at the (I think 115,000km service) it gets spark plugs changed? Could this be the issue?
    I change the oil every 5,000-7,500km, and maintain it well.. I'm changing the oil at 110,000km, so should I do the plugs then if it's possible to be those?
    Sorry for rambling on haha.. Any ideas/help is appreciated.
    Sent from my iPhone using Tapatalk
  2. stick3
    stick3 Member
    newcastle nsw
    vz sedan vs ute gsx1400
    have u change air and fuel filters
  3. Supe
    Supe Supe
    Rural NSW
    VE Calais 6.0
    Low fuel pressure, dying fuel pump? Ask Holden to check the logs.
  4. vicarious
    vicarious New Member
    SA
    VE2 SV6 SPORTWAGON
    hows the condition of the battery?
  5. kizza50
    kizza50 New Member
    VX acclaim S2
    Fuel filter is non serviceable
  6. calais06
    Sydney, NSW
    VE Calais MY06
    Air filter is a new k&n panel that came with the OTR, havent changed the fuel filter, always run 98 octane.
    About a month ago I had the logs checked and there was nothing about fuel filter, I'll get it checked at the service.
    The battery dies pretty quick, like when installing the amp the battery didn't have enough power to fully crank over, but I assumed the battery would b ok cos it was cranking fine, just not firing?
    Thanks for the ideas :)
  7. RiCeY
    RiCeY F O R U M W A R R I O R
    Australia
    VZ SV8 6spd 5.7
    There arent any "logs" unless an event occurs that logs DTC's.
    Generally when an engine related fault occurs the engine light will illuminate.
  8. stick3
    stick3 Member
    newcastle nsw
    what a stupid pita idea, u dont want to get any dirty fuel also i will be adding a capful of metho to help evaperate moisture,every few tanks
  9. RiCeY
    Australia
    VZ SV8 6spd 5.7
    Where will it evaporate to? The tank is sealed and the fuel cap only allows air in, not out.
  10. Longman
    Longman New Member
    Newcastle NSW
    VE Calais V 6.0 Auto
    Time for a battery change? Have you ever replaced it since getting the car?
  11. stick3
    stick3 Member
    newcastle nsw
  12. stick3
    stick3 Member
    newcastle nsw
  13. calais06
    Sydney, NSW
    VE Calais MY06
    I haven't changed it, looks original.. Would it be the battery if it's cranking fine just not starting?
  14. vicarious
    SA
    VE2 SV6 SPORTWAGON
    cant hurt to change it,being 5+ years old it will die sooner or later if its not in that state already, the next battery i'm getting is an optima, so i can then have a bar fridge in the back of the wags.
  15. RiCeY
    Australia
    VZ SV8 6spd 5.7
    If its cranking fine dont waste your money on a new battery,
  16. kizza50
    kizza50 New Member
    VX acclaim S2
    Crank angle sensor
  17. calais06
    Sydney, NSW
    VE Calais MY06
    Was the battery :)
    Went for a long drive a night before and then the car wouldn't start or crank the next morning, got a new battery (old one was original, going on 5 years old).
    Started straight away, fires quicker, all good :)
  18. ree
    ree New Member
    gold coast
    VE SV6
  19. ree
    ree New Member
    gold coast
    VE SV6
