sydsider
- Jun 24, 2022
- 141
- 40
- 28
- Age
- 58
- Location
- Sydney
- 08 VE Omega
So ive just had a P0500 come up as the VSS circuit. Now this is interesting as ive been trying to find out what the tranny issue has been for 2 years since ive owned it. I saved something about the VSS causing shifting problems if faulty a while ago. I hadnt got around to checking it out. Pedal needs feathering slightly to get it to upshift, and then its with a clunk. And when downshifting to turn a corner, its like it goes down to first, and revs out a little then changes to where it shouldve been in the first place into second.
Its like going around a corner in first, when it should be in second in a manual tranny. Thats the best way i can describe it.
Ive just done an oil change with AC Delco dex3 and replaced the 1-2 accumulator piston with aluminum as well because its prone to cracking and causing above shifting issues.
Changed the 1-2 servo seals as thats another area that causes it.
So ive ordered an AC Delco VSS for $66.00 off of Ebay hoping its that and not the harness. As far as im aware, when theres a faulty wheel speed sensor, it shows up on the dash as ABS as i have in a video on Youtube on the VE commo. I dont have that.
No code for faulty wheel sensor.
So my VSS must have been on the way out for at least 2 years that i owned it and the rest from the previous owner/s.
Any one had any of the shifting issues with a faulty
VSS?
ABS/wheel sensor code. VSS harness.
The ABS fault on the dash.
VSS?
