Vicroads tare weight thread
Discussion in 'General' started by foammedia, Jun 4, 2006.
  1. foammedia
    foammedia Guest
    You may put other states rego weights in here too, but I mainly want to see if the Vicroads ones are in anyway realistic first.
    Here's some to get it started.
    1990 (V6 GL) Lexcen sedan
    Tare 1300
    1992 (V8 IRS executive) Holden Commodore sedan
    Tare 1277
    1995 Jeep Cherokee sports
    Tare 1700
    I'm sure the VN and VP both weigh closer to 1400kg's and I know the Jeep is no way even close to 1700 kg, more like 1500kg
    Anyway what's on the rego sticker of your car/s?
  2. foammedia
    foammedia Guest
    I see you are all very willing to go outside at look on the rego sticker :p
    I went to my shed and got the VH SLE's weight
    1982 Holden Commodore VH SLE (auto 202)
    Tare 1300
  3. 1vngal
    1vngal New Member
    North Tassie
    'Ruby' 1991 VN Exec & '98 Proton M21 Coupe
    Oh right!! I get it!! It was just a trick to get me outside in the freezing cold!!
    Well it worked...
  4. Wombat
    Wombat New Member
    Bluff, Queensland
    VX-II Lumina Sedan
    Don't seem to have that up here in the Sunshine State...
    Brings up a point I have always been sore on however...with modern materials available, it is just laziness on the designers and car builders part that a new Falcon or Commodore is pushing 1800kg.
    There is no reason whatsoever that a car that size should weight any more than 1300 to 1400kg with the performance and economy gains that would bring. Jeez, our old 1978 XC-update GXL Fairmont with an all-iron 4.1 liter crossflow engine, massive steel bumpers and heavy panels only weighed about 1400kg...
    Alloys, light weight materials for the interior, and so forth, would help. God, imagine how much extra a new Commodore would weigh if the Alloytec wasn't all alloy? As for heavy wiring systems, quite some years back SAAB and I think some Jap makers came up with the "single wire" possibility. Instead of a massive bundle of wires there would only be one single wire running back to, say, the taillights, and depending on which type of signal was sent, you would have indicators, brakes, or taillights, or a combination of them. I seem to recall it being operated on a system of internal relays inside the lights and other systems that the single wire would send power and a "message" to about what to light up or operate. It made the wiring system a small percentage of the weight of the original, and much simpler to work on and install. I don't know if anyone went with this system into production though, but sounds quite a good idea to me.
  5. YMY-88U
    YMY-88U New Member
    Project VH SL/E
    my tare weight for my 1991 vn berlina is 1480kg
  6. Shounak
    Shounak The Kicking Horse
    VX Executive S2 + XF Panel Van Project
    Either 1350 or 1450.. I'm 90% sure it's 1350, but I cbf checking it..
  7. STEALTHY™
    STEALTHY™ So Wet For You!
    SA - The Roadworks State
    Gross weight for my VP Calais is 1642kg, we don't have tare's here, but thats shows the comparison of how far they are out
  8. Ripcell
    Ripcell R8 FTW!!!
    East Melbourne
    324rwkw MY06 VZ R8 Maloo M6
    mine says 1650kg on the VXII Acclaim
  9. ucwepn
    ucwepn America just kicked in yo
    WH statesman 5.7
    mine says 1350 from memory which is way off LOL vl is a damn sight smaller than a vn or anything newer.
  10. MBS206
    MBS206 New Member
    Give me a new commodore, weighing in at 1800KG, and I bet I can bring it back to at least 1500KG, and you wouldn't even be able to tell the difference in what I took out.
    Have you noticed how all new cars are so much quieter then older cars?
    Gee, try getting in a merc or similar. You can't hear a thing, due to the 200-300KG of sound deadening... That's where your weight comes from.
  11. jules
    jules we like the bun
    pimpin
    most of it really comes from all the extra modcons fitted to modern cars. servo motors, climate control, cd stackers, electric seat motors. it also comes from beefier bodies demanded by crash test requirements. 18" inch wheels will weigh more than old 15"ers, etc.
  12. minux
    minux Infidel Bear
    Series 2 VT SS 1576kg
  13. minux
    minux Infidel Bear
    How would you tare weight be out? No fuel, no oil's, no fluids. Calais are heavier in all models....
  14. foammedia
    foammedia Guest
    I'm starting to think this vicroads tare weight is pretty spot on. All the more reason to add more of them to the thread :), Who's got an early V6 VN executive? or budget model VB?
  15. ashzv6
    ashzv6 New Member
    VN v6 s2 Berlina 5spd
    i cant beleive how they range so much:
    my first car vn series 2 v6 manual executive wagon weighed 1350
    my current car vn series 1 v6 manual berlina weighs 1200
    my mates vn series 1 exec weighs 1300
    why does my berlina weigh less?
    anyway just thaught i'd share my bit
  16. xlr8_87
    xlr8_87 No longer a commy driver
    Melb, VIC
    '96 Prado 4x4
    tare for mine (VP) is 1350 according to rego
    i'd assume she's closer to 1450 with LPG setup and fuel
  17. greenfoam
    greenfoam New Member
    VP Executive R-spec
    Asked a dude that has a full spec IRS/ABS VP Calais
    1993 (V8 IRS Calais) Holden Commodore sedan 1450kg
    He also told me his two mates VN Calais are
    1990? (V8 Calais) Holden Commodore sedan 1400kg
  18. greenfoam
    VP Executive R-spec
    Your mates executive would be an auto, it's heaps heavier
  19. Reaper
    VZ LX8 Adventra, VP SS
    It isn't so much laziness. Given half a chance the engineers would have us all driving around in carbon monocoques doing 4 second 0-100 km/h. Unfortunatly commercial reality has to be listened to and there simply isn't the money to do everything they would like. Keep in mind that making cars isn't the most profitable business to be in these days.
    Reaper
  20. Reaper
    Vicroads Tare is pretty good. My friend crushes old cars for some extra cash. He says the rego weight is usually plus/minus 25kg of the actual weight when he puts it over the weigh bridge and has done hundreds of them.
    My VYII SS Manual has 1400kgs on the rego.
    Reaper
