VK LS1 AC (Air Conditioning)
Mario K
51
VK
Hello,
I want to install AC on my VK which has an LS1.
I purchased castlemaine rod shop AC bracket and compressor.
https://www.rodshop.com.au/high-mount-air-conditioning-ls1-ls2-ls3-engines
This Kit Uses the Sanden 508 Type Compressor
Now i need to purchase the condenser and receiver drier.
Do i just buy standard VK condenser and receiver drier?
https://www.ebay.com.au/itm/1736623...MItqLVhbrvgwMVn6RmAh2KHwTlEAQYAyABEgJQgfD_BwE
Also where do i go in Sydney area to purchase a pipe kit?
Thanks
Muzza
shane_3800
35
places
vr commo
You need to get a A/C shop to install the piping, technically any A/C work needs to be done by a licenced A/C shop.
They will make all the hoses and lines to a custom length and swage the fittings on ect.
Unless the A/C compressor is in the exact same location and uses the exact same fittings custom hoses and line will need to be made.
It's quite simple to do it for an A/C shop.
The A/C shop will be able to sell you the condenser.
Lacksballs
www.youtube.com
VK Group C Replica, 1995 VR Sedan
It will be easier if the VK had AC as an option when built, you should be able to marry the LS compressor into the VK dryer/condenser & dash switch. I’d replace dryer when making the new hoses.
shane_3800
35
places
vr commo
Yes. But if it didn't have A/C there's aftermarket evaporators available.
Mario K
51
VK
thanks, you are right on the license its for the gas only, however anyone can cut a pipe to size and crimp a fitting, its not rocket science.
where did you get the hoses from / fittings?
Lacksballs
www.youtube.com
Hey Mario, I just went to an “automotive” AC specialist with a measured bit of string noting what I wanted & they made up the hoses, then once together I drove it back & got it re-gassed. I can’t remember the place exactly but was somewhere near Alexandria. You definitely need AC in Sydney with all that glass in our VK’s.
gtrboyy
vt ss & lc gtr
Gizmo Auto Electrics be worth a try...theyre in Sydney & do alot of Ls air con stuff etc so probably enough Ls early girls out there with air con.
