VL Turbo - What Now?
35
Cairns, QLD
VS S Pack Ute
Ok, I have recently aquired a VLT Calais (manual) that has just recieved a rebuild to the engine and the turbo. It already has an intercooler and a blow off valve (that shall be going asap....)
I would like to eventually push around 200rwkw.
What sort of build path do you suggest I follow?
I really do not know a lot about VL's and not much more about turbo's.
Anyway, any help and/or suggestions would be much appreciated.
STEALTHY™
So Wet For You!
SA - The Roadworks State
You can do whatever you like, as long as you don't put inters on it.
Immortality
Staff member
Sth Auck, NZ
i'd suggest you look on the turbo calais web site. i don't think that 200rwkw should be that difficult from a VL turbo. is it a stock rebuild and stock turbo?
Dose Pipe
At the time of this post, under your mothers bed w
It's quicker then your mothers VN
high flow turbo, 3 inch exhaust from turbo back, boost controler, 14psi (get boost done on a dyno) and should get close to 200rwkw in a manual
35
Cairns, QLD
VS S Pack Ute
Lol everyone says the calaisturbo site... but i like jc :(
ummm, the turbo was rebuilt to stock i believe but i was told that the engine was strengthend (better pistons, balanced crankshaft, block rebored/honed... that sort of thing.... not terribly sure of the details too much lol. the receipts were kinda annoying to read lol)
dreamcatchu
sick puppy
Bundaberg qld
VC Commodore
basic rule for turbos is more boost less compression, so if your gonna increase your boost your best of reducing your compression
Immortality
Staff member
Sth Auck, NZ
just a bigger turbo with decent exhaust and intercooler should see you hit 200rwkw as long as the CR is suitable as mentioned above. i think guess are getting close to those numbers on almost stock bottom ends so with a rebuild it should be sweet, could probably handle more
JD
Donating Member
37
Deep South, SA
www.ccgm.au.tt
1.6L Turbo Holden Croooooooooooze
Get some wog mates, live the world of Fat Pizza :D
oky
58
2012 sv6. my12
I had a VL Turbo RB30 You can put your turbo at 11.5 boost with a bpr 7 spark plug they are a little colder and 8mm leads and a 2.5 or 3inch exhaust. you also need to add some fuel a little rich and it will go down the 1/4 mile in 13.8 or 14sec no intercooler needed. That is faster than a XY Falcon GT super roo 1971 Mussel car and a e49 charger
STEALTHY™
So Wet For You!
Wow how much power does your excavator have?
