VN heater valve / tap stuck on cold
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by moose, Feb 9, 2009.
  1. moose
    moose New Member
    VN Executive 3.8
    My heater controller was stuck on cold and I couldn't turn it to hot. After disconnecting the controller mechanism I traced the proble to the valve on the heater itself. It's stuck solid on cold. It happaned suddenly and without giving me any warning, ie. it didn't play up at all, was working perfectly than one day it stopped. Does anyone have any idea how to fix it without replacing the heater itself? The bit where the controller arm scews on looks like plastic so I don't want to force it in case it snaps. Any ideas would be appreciated.
  2. moose
    moose New Member
    VN Executive 3.8
    ok.. fixed it...since I saw a few posts with this problem but no solutions I thought I'd say what I've done. Took the white, plastic arm off the valve and got vice-grips on the valve. Applied a little force while pushing and pulling it in and out (it has a slight movement) and it finally let go. I tried pliers but couldn't get enough grip on it. I know it sounds drastic but I only applied enough force not to break it. Got my heater back.
  3. 88GreenVN
    88GreenVN Next Exit Left
    Elizabeth Vale
    2000 VX on Gas
    Good work - and you didn't bust the plastic bit - sooo easy to do
  4. moose
    moose New Member
    VN Executive 3.8
    nope... I made sure I didn't force it too much...but I had to get a good grip on it...pliers just scraped it.. hence vice-grips... it worked.. :)
