fergi
- Oct 23, 2003
- 232
- 1
- 0
- Location
- HAMLET BRIDGE
- VP 5 LITRE V8
i have left a post in vp on installing a cd deck in my vp, left it in there before i realised that this was the place to leave it so i will write it here ,, i have a vp and it has standard cassete deck and two front speakers,, i want to have a cd deck in place of the standard unit and replace the 10 cm front speakers with sony ones and then put sony 22 cm ones in the back, there are no holes cut yet so is the procedure to pull out the carpet on the back shelf ,mark out the template and cut holes from the top with jig saw or do you cut from inside the boot,.also there are two white plugs hanging inside the boot at the top i assume these are the plugs for the rear speakers in the standard wiring loom.is the olsd cassete player easy to get out and put in a cd deck.auto barn here in adelaide want 180 dollars to do the fit but i would rather do it myself if its not to hard and save the 180.dollars
cheers
fergi
cheers
fergi
