VR VS Calais fog lights bezel cut out
ephect
Donating Member
VS Acclaim V6
Vr vs should be a curved lens and defined left and right, the vt were flat.
Wozza
VR_GS commodore
Also does anyone have a picture of the actual fog lamps in place (fixed to the vehicle)?
remove the reo bar makes it easier in the long run...they dont fit snug in the cut out they more or less peek out from afar lol
stick3
newcastle nsw
vz sedan vs ute gsx1400
these were painted and install by a panel shop about 10 years ago i supplied the clips bolts slide nuts which i got from holden and lights, bezels, wiring looms from ebay
stick3
newcastle nsw
rare spares have screws instead of bolts with the slide nuts https://www.rarespares.net.au/rarespares/buy/fk1145/fog-lights-front-indicators-fitting-kit-vr-vs
genuine wiring looms from ebay
Lacksballs
www.youtube.com
VK Group C Replica, 1995 VR Sedan
Thanks, mine are VT ones just googled the part numbers!
stick3
newcastle nsw
now that you mention it i just looked at the pics and they do differ hopefully you can exchange them for vr/vs
ephect
Donating Member
VS Acclaim V6
Lacksballs
www.youtube.com
Fitted LED bulbs and wired them into an additional relay in the fuse box.
I wired them up as DRL’s.
(FYI: the park lights are switched on as well in this picture just for effect)
