Cloudraccer
Can anyone help I have a vs berlina v6 auto started to hiccup on start up when cold in idle slightly a few times go away then occasionally do it when driving this has esculated to hiccup then stall in idle also when driving this is what I've changed and done new plugs,leads , coils all 3 new ,dfi module ,iac valve ,throttle body sensor both changed new , swapped map sensor with a mates map sensor of same car in which his works fine still doing same thing ok took to a mechanic he checked all sensors cas , co2 sensor , cam sensor , did fuel pressure test checked egr valve all ok Jesus what can it be he even erased old data on ecu and remapped and tuned it in which it runs smooth and responsive like it's never run before btw I've had the car since new 1996 till now 2016 1 owner I've kept the bloody thing immaculate and never had any niggly problems like this before driving me nuts also today had trouble starting it cranks and cranks then bingo it will start idle in warming up hiccup here n there but drives fine besides a few hiccups or misses if you want to call it a miss it's very slight got me beat can anyone help cheers frustrated
