VS Commodore Wiring Diagrams
Discussion in 'Electrical Wiring / Questions' started by nparsons, Feb 2, 2010.
  1. nparsons
    nparsons New Member
    VY 5.7
    Hi,
    I'm looking for a wiring diagram for a VS Commodore.
    They seem to be hard to come by.
    None of the boot lights are working. Seems to be an earthing problem.
    Any help would be gratefully appreciated.
    Regards,
    Neil.
  2. markovr
    markovr Well-Known Member
    northside brisbane
    94vr 5sp .04vz wgn,93vp wgn,82 vhV6 wgn ,88 vn 5sp
    Looks like if its factory fitted, the earth for the tail lights in the boot goes back via a black wire (theres no actual earth lug that goes under a screw in the boot) that runs back to the front of the car and that goes through the multipin connector under the right hand kick panel to then feeds the bcm ...the earth point on the body near the battery connects to the bcm to provide the circuit to earth the tail lights when the bcm enables it ...part of the auto lights off feature... for the 12v+ feeds to the tail lights under the steering column fuse 1 feeds the parkers and fuse 8 feed the stop lamps
  3. Devils_Thunder
    Devils_Thunder Riding high...
    Wahgunyah, NE Victoria
    2010 Captiva.....
