vscom88
Andrew-
- Dec 21, 2008
- 200
- 2
- 18
- Location
- melbourne
- VH Commodore
My ecotec (l67 top swapped) runs like a bag of **** and fouled up 4 of 6 iridium plugs only when cold. It's currently in a for a tune but we can't get the damn thing going properly despite mucking around with AFRs and map/maf tunes.
It would idle lean (as per the wideband gauge) and once at operating temperature it would be fine. It has since, leaving my house, decided to cross fire and back fire in the left exhaust bank in the extractor at the collector. I have 9mm eagle leads, iridium plugs which we swapped out for brand new std ngk ones, coilpacks from mace engineering (not msd) and a Bosch dfi off eBay (both done in 014 when it was running like poo when cold). I have injectors that have been serviced by myself but not flow tested (will be replacing them with flow tested ones I bought).
I had it going OK then we put an old map tune in with a map sensor and adjusted it to suit for the further mods and now even reverting back to a stock maf tune it just sounds like it's cross firing.
The car doesn't want to run right when cold but when it heats up it runs ok. Initially it was just running rough with the occasional pop in the exhaust and idling at about 16.5 there abouts.
I fitted a 4" intake pipe on and stuck the maf on the very end which caused it to start back firing from just running rough.
A quick run down on the mods are;
Fresh block and heads with just 6000ks on it.
Oversized valves, forged pistons @ 40 thou over size. Block been decked to 0 and heads modified to suit extensive lift. (1:98.1 mace rockers and .307" on the cam) it has LS1 throttle body and wide band o2 sensor in the passenger side exhaust bank. 10:5.1 cr, 87mm pulley and l67 injectors with new o rings and baskets. I have 1000cc injectors for when it goes to e85 which aren't being used yet. It also has a new fuel filter with a new 450lph wallbro e85 rated fuel pump.
I've missed lots of stuff so if there's anything else you need to know I'll answer it.
This is driving me crazy and I just want to sort it out.
