VS Series2 BCM wiring diagram
Discussion in 'Electrical Wiring / Questions' started by monarols71, Jan 17, 2005.
  1. monarols71
    monarols71 New Member
    VS Series11 Ute
    Hi guys and gals,
    New to this site, but what an excelent site it is.
    Not a gimme, but does anyone have the wiring diagram (inputs/outputs) for the VS series2 BCM (low, mid, high).
    Being the proud owner of a VS Series2 Ute, I want to upgrade the body components if I can. Starting with an electronic aerial, possibly power windows, trip computer, etc. Is it better to upgrade to the better BCM, then downgrade inputs, or stretch the lower module, and stretch to the upper limit of the inputs.
    Put an electronic aerial in, and found the wiring loom didn't have the required connector. I thought the newer models had all the wiring done, only needed the appropriate "inputs" to get it to work.
    I put the aerial in, and found nothing to plug the connector in to. My aftermarket manual doesn't give the input/output of the BCM. :drink:
  2. Garth
    Garth Your guess is as good as mine......
    100 series Toyota Landcruiser V8 monster
    your in luck
    stumbled on this today,valuble member of this forum's website, give it a look, this guy is high up in the memcal/bcm/pcm side of things, no harm in looking
    http://www.memcals.com/wiringdiagrams.htm
  3. monarols71
    VS Series11 Ute
    Thanks for that. Great for engine conversions etc. as they seem to be ECM drawings, but I'll keep searching.
  4. Doctor Bob
    Doctor Bob Grandpa
    Mornington Peninsula
    VT V6 Exec & VN V6 Exec
    I am presently working on some non copyrighted wiring diagrams for my site
    Cheers Rob
  5. monarols71
    VS Series11 Ute
    Hi Rob,
    I will gladly proof read them if required. ;)
