Thorney355
- Nov 27, 2016
- 2
- 0
- 1
- Age
- 38
- Location
- ipswich qld 4305
- 1999 series 3 v8 vs commodore ute
hi my vs series 3 v8 commodore ute feels under powered has new fuel pump new adjustable fuel regulator. fuel pressure is spot on. has new air flow meter plugs leads dizzy cap rotor button. throttle body sensors are all new. thought it maybe oxygen sensor so replaced it with
bosch 0258 005 703 witch is direct replacement for AC Delco AFS75. now the problem is still under powered and when on the highway about 2000rpm for about 10 minutes throws engine light up for oxygen sensor but everytime check for problems reset fault code does it again but it will change from lean fault to rich fault all the wiring harness is ok has good earths to oxygen sensor thought it might be vacuum leak as series 3 utes run A/F meter no vacuum leaks. had ecu checked and its fine even swapped it with my mates series 3 ute made no difference. im out of ideas any suggestions would be great thanks
