vt power window wiring diagram
r600
52
newcastle
v8 vn berlina-vt series 2 wagon
hey i have vt i want to put power windows in ,i know the body control module is different but was thinking about not running through that doe anyone have a wiring diagram??????cheers adrian
paulbenning
Bolton point Newcastle
VX Executive
you should have all the wiring to do it, all I did when I installed power windows in my VX was to change the door looms and cut the wires from the drivers door and run them to master switch to by-pass the BCM hopes this helps!!!
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
I've posted this before, a search should have found it. Open attachment in a new window for a bigger view.
r600
52
newcastle
ok my bcm is 313 mid level can i just wire it into this or do i need holden to do something to tell it has power windows???also are sedan rear window power regulators the same as wagon?????????cheers adrian
BB63
Redcliffe
VY Crewman
Does anybody know if this diagram would be the same as a series 2 VY Crewman, and if not where I could find a diagram to suit?
I have tried searching and this is the best I have found so far, please help.
Cheers Brian
