ohwow
- Feb 16, 2013
- 11
- 0
- 0
- Location
- Australia
- VT Commodore & RX8
No, this is not another speculation as to whether a VY dash will fit into a VT.
I have already completed the majority of the work, however I have not quite finished.
Here are some images of my progress so far:
*Note all the food required to complete this job (Beers not pictured)
So anyway, the dash is in, sits nice, looks nice, and no creaks etc. I am still missing a few parts such as the radio etc and a few trim panels are missing or damaged (along with the glovebox), but the majority is there.
Here are my issues:
Headlight switch I can trial and error and figure out myself, but the other two I'm a bit confused. So does anyone have any insight as to how I do this?
I got this far however, so I'm sure I can finish the job.
Here are my issues:
- Cluster - I am yet to purchase one, and from what I have read, they WILL work with a VT with simple rewiring. However, I do not have the loom to wire to, nor do I have any idea where I would get a cut up loom without buying the entire harness (which I would rather not do).
- Hazard Switch - Exactly the same problem here. Will wire up fine, just don't have the loom.
- Headlight Switch - For this one, I had the cut loom from the VY. I've wired it up all fine, with the exception of the Auto function (which I don't care about). My problem with this one, is the brightness switch does not function. All it seems to do is when the vehicle is off and keys are out is turn the headlights on when moved to the brightest position (I assume I've wired it incorrectly, however I do not know which wire is the culprit)
