VT V6 PCM Pin/Wire diagram
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Foxmaster, Oct 28, 2009.
  1. Foxmaster
    Foxmaster New Member
    Bathurst
    VT V6 commodore/Hilux
    I am after the wiring diagram for the PCM, trying to find the speed senor wire and the fault wire from the PCM of a VT V6 1998 can anyone help?
  2. wamboin23
    wamboin23 Donating Member w/ Boost
    Wamboin, NSW
    VS Calais - Cooled L67 + T56 | VR Acclaim V6
    purple white is speed sensor. no engine light wire, it is run over the CAN network. its all serial data between all the modules and the dash.
  3. Foxmaster
    Bathurst
    Thanks Mate! is there a number above the purple wire, I think that there is more then one purple wire coming out of the PCM, I don't have it here to look at.
    Thank you
  4. wamboin23
    Wamboin, NSW
    theres two im pretty sure, and im also pretty sure they both have the same pulse.
  5. delcowizzid
    delcowizzid on holiday
    NZ
    в∞ѕтεכ √&
    auto speedo input is C6 and D5 from the vss to the ecu if thats what you are after
  6. mwb235
    mwb235 Guest
    Here is a VT series 1 3.8L V6 Ecotec wiring diagram for the PCM/engine.
    The attached image may be too small to read as this forum doesn't allow higher resolution attachments. If so send me a PM with your email address and i'll email it to you.
    For the benefit of others, see my posts in these threads for some other VT Series 1 PCM wiring diagrams (if anyone needs these please PM me with your email address also):
    3.8L V6 Supercharged
    http://forums.justcommodores.com.au...0-need-supercharged-vt-v6-wiring-diagram.html
    5.0L V8
    http://forums.justcommodores.com.au/vt-vx-holden-commodore-1997-2002/113372-vt-wiring-diagram.html
  7. chargemeup
    chargemeup New Member
    YP Executive S2
  8. mwb235
    mwb235 Guest
    chargemeup, done
  9. livestockpimp
    livestockpimp New Member
    VT Calais
  10. HUMBLZ
    HUMBLZ New Member
    VZ
    anyone know where the oxy sensor sender wire is?wanting to hook up a/f gauge to a VY
  11. Claudy
    Claudy French Com
    Perth, Two Rocks
    Manual Gen3 VT SS + V6 VT manual turbo
    standard V6 diagram please claudy.boulaye@gmail.com cheers
    or im after the colours for reverse lights in a vt getting converted to manual
  12. Pcracing
    Pcracing New Member
    Portland
    Vt spac twincharged
  13. dodgie12
    dodgie12 New Member
    Gold Coast
    VT Berlina Station Wagon
    Hello Was wondering if you could email me the VT series 1 3.8L V6 Ecotec wiring diagram for the PCM/engine gchar2@gmail.com
    Thank you
  14. mwb235
    mwb235 Pierced sink plugs
    NSW
    Not sure if you still want it, i only just saw your post. Wiring diagram sent.
  15. Claudy
    Claudy French Com
    Perth, Two Rocks
  16. mwb235
    NSW
    I was gonna send it to you too but saw that your earlier post was 2 years old so i decided not to.
    Anyway i just tried to email you but it comes back "Mail System Error - returned mail". Do you have another email address?
  17. SweetWagon
    SweetWagon booosted
    Springwood NSW
    VS Berlina Wagon Supercharged
  18. Claudy
    Claudy French Com
    Perth, Two Rocks
  19. mwb235
    NSW
    that's ok, email sent.
  20. The1
    The1 A Memcal a Day Keeps..
    Toowoomba QLD
    VS V6 Berlina Auto
