VT/VX RetroFit Guide for: VN/VP/VR/VS
azkwazere
Ahhh Yes, Ahhh Yes....
.....SE Burbs
VP 5-SPD / 24-SPD Racer Hybrid
The only thing left it to attach your electronics, if you have any.
4way elec seats are a simple +/- setup. 8ways need a BCM which i dont know how to setup. With the 4ways, just wire up the seat with + to acc circuit and negative to earth. Use a relay.
And thats how you fit VT/VX seats into a VN, VP, VR, or VS commodore.
azkwazere
.....SE Burbs
FAQ:
The metal strapping split, what am i doing wrong?
ANS: The metal isnt hot enough when bending, heat more.
There isnt any holes on my VN for the centre rear seat, what do i do?
ANS: You need to make some, VNs had a single rear back rest. Use a drill and self tapping large screws to affix it.
Is this a legal modification?
ANS: No, i dont reccomend you attempt it either, i have since removed mine due to legalities :whistling
Why use 5mm Steel?
ANS: You need somehting which will withstand alot of weight, its for safety mainly. I would want somehting that wouldnt break in an accident, if i had them in my car... which i dont....:whistling
FATMAT
Coffs Harbour
VT V6
That's a really good set of instructions mate, i was under the impression that only vn-p-r-s seat will fit, and there was no possible way of retro fitting vt-x seats into vn's. And to have the electrics working is insane, that thread just made my day!
Next mod: VT-X electric seats :yeah:
azkwazere
.....SE Burbs
Cheers mate, yeah they fit and they are awsome :)
aZk.
44
Wollongong
VH SL Wagon
if you mount the front seats using the vr/vs rails this would be legal i think as you are using the factory mounts
i'll look into it further as i almost bought a set of vx seats for my wagon on the weekend and would rather it be legal.
does anyone know if a vt/vx rear wagon seat will fit a vr/vs wagon?
st3r3otyp3
Donating Member
VX HSV VX SS
Better method than re-using the ring curls
Instead of re-using the rings when swapping the frames over use long cable ties as this is a less punishing method and no blisters :thumbsup:
bar that excellent write up az.
vs-6
Raptorcharged VS
perth claremont
VS S pac V6
ok vt/vx seats would look awesome in my vs but wat about vy seats they are blakc and look heaps better as the vt has same floor pan as vy cant imagine it being too much different ill make it fit anyway should be doing it soon shall let you know how it goes
Vg-ute-mad
51
Whalan, N.S.W
VS 97 Series II
Cool. Are they Exec seats? Black seats would suit me too! :)
