jonno_2002vuss
- Dec 27, 2016
- 8
- 0
- 1
- Age
- 40
- Location
- Newcastle
- VU SS
High ladies and gents. I'm having a few issues with my vu ss. Firstly I am having a high idle issue where it will idle between 1500 to 2000 rpm. This is intermittent but more often than not its high. Ive changed maf,tps,iac, knock sensors and they're wiring harness(only code that showed up), ive cleaned manifold and throttle body, ive done an injector service also. It drives ok with no miss although i only get about a quarter pedal out of it and after that it seems to retard itself. Im not sure on condition of the new tps because if its unplugged it will idle normally until plugged back in. The second problem is with the headlights where when high beam is on the fog lights come on. The fog lights wont turn on or off with the switch. The fog light indicator and high beam indicator are also dim.
