vx acceleration response?
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by daz08, Jun 1, 2005.
  1. daz08
    daz08 New Member
    MY11 V6 Calais SII
    Hey guys, just wondering is there any way to change the acceleration reaction time? I mean, when i put my foot down it will take a couple of seconds bfore it actually kicks in and goes. Is there a way to change it so when i put my foot down i have instant acceleration??? :confused:
  2. troyjm310
    troyjm310 New Member
    Wesside Sydney
    VEII Sportwagon SV6 Z Series
    ive been told that if u have a thicker guage earth wire running from one of the bolts or around the disy well yeh to somewhere it makes it more responsive
    i will find the full details and post later !!
    totally forget sorry :hit:
  3. Mountain
    Mountain Guest
    Bigger throttle body
  4. daz08
    daz08 New Member
    MY11 V6 Calais SII
    Does a bigger throtle body do much for a v6?
  5. oshe
    oshe Guest
    is there a bigger throttle body for the ecotec v6?
  6. Redfox
    Redfox New Member
    Nope, you gotta get it bored. Or buy a modified one. I found that hi ratio roller rockers made the throttle response a bit sharper.
  7. oshe
    oshe Guest
    were they yella terra? how much?
  8. roy38
    roy38 New Member
    thunder
    stage 2 cam cai exhaust chip valve springs and roller rockers should give ya a nice kick up the arse also before you buy anything tighten the throttle cable and kick down cable throttle cable is the easiest thing ever to tighten dont even need tools
  9. jase_vs_comma
    jase_vs_comma New Member
    vs equpie s2
    i spoke to holden bout this problem wif my vs they said they could fix it for 400 buks, its sumfin to do wif the solinoid, ill b havin this fixed in the next few months ill keep u's updated
  10. VTS5
    VTS5 TechJunkie
    Sth.East\Melb
    '97 VT Spack 5 Speed
    B4 you book the car in for that service which takes about half-an-hour to do spend about $14(i think) get a tranny Nulon enhancer/conditioner.You'll be suprised with the result(it works most of the time).
  11. aza64
    aza64 New Member
    VX 01'
    m8 my 00 VX has instanst thottle response. which can get rather annoying on bends and roundabouts when you just tap the gas it just pull of at once. your lag can be so to with your diff or either that car isnt tuned to the currect setting it should be
  12. muso
    muso New Member
    South Australia
    BA xr6 turbo Heinrich tuned to 300 rwkw's
    What is a "tranny Nulon enhancer/conditioner?" It hasn't got any thing to do with having a sex change has it?.....Sorry, but seriously what is it? Something to do with the transmission?
    My VX used to miss and hesitate when taking off quickly but a set off Topgun 8mm leads, new plugs and a throttle body clean helped a lot, the missing was so bad that I thought the gearbox was on it's way out, but holden were right, it was the leads, the skinny little 6mm stock GMH leads.
  13. Bax
    Bax Projecting
    QLD
    Nothing
    How about just better gear selection.
  14. VTS5
    VTS5 TechJunkie
    Sth.East\Melb
    http://www.nulon.com.au/prod_G60.htm
  15. muso
    muso New Member
    South Australia
    Thanks VT_acclm, I'll look into it, sounds like a good idea.
  16. Stretcher Bearer
    Stretcher Bearer A.R.N.G.
    VT2 SOCOG Exec 9C1
    Use the power button!
    You can get your tranny reset via GMor someone else smarter.
    Mystarted to change ridulously and with a ECU reset it worked like a charm!
  17. OLS108
    OLS108 MR Helpful
    QLD
    Stockish VX Berlina
    Mate my VX does 0-100kph in less then 5 seconds, maybe you just need a V8 ;)
  18. Damo2210
    Damo2210 New Member
    geelong corio
    vx ss 2002
    All I Changed Was My Air Filter On My Vx To A K&n Air Filter It Has More Go And More Responsive.
  19. Stretcher Bearer
    VT2 SOCOG Exec 9C1
    Cos you really need it it! :w00t:
  20. EXCESSV
    EXCESSV New Member
    Perth, WA
    VE SSV
    Boys boys.
    The simple and best way to improve take off response is a simple diff ratio change.
    My VT had 3:08 which is standard and all i have done is change it to a 3:45. you would be surprised how much of a grin it will leave on your face when you drive it away from the diff joint.
    BUT a warning: make sure while they have the thing apart they change seals and all the stuff. its worth the extra money now then when you need to do it later.
