VY Engine Error Codes
Discussion in 'VY Holden Commodore (2002 - 2004)' started by Secki, Mar 13, 2006.
  1. Secki
    Secki New Member
    Southern Highlands
    VH Wagon SLX 253
    Does anyone know how to reset the service reminder in VYs, and also how to bring up engine error codes? i assumed it was the same trick as VTs but it doesnt appear to work?
  2. Aggro_VE
    Aggro_VE The Overseer
    Lake Macquarie
    A lazy VE
    Try this mate..
    Turn the ignition off
    Press and hold the trip computer UP and DOWN arrow buttons
    Turn the ignition on while holding the buttons
    After approximately 3 seconds, release the buttons.
    The service menu appears with a reset request.
    Press and hold the SET button for more than 3 seconds.
    Press the MODE button
    And to get into the other functions, hold Mode and Set while you turn ignition on, then hit Mode to go thru the functions till you reach Trouble codes with alot of zero's, thats what you want and that's all you want :).
  3. sickvy
    sickvy Guest
    I have looked at the error codes and found that it looks something like this:
    0000000000000
    1000000000000
    Don't no exactly how many zeros on a line but it has a 1 at the start of the second line. Wat does this mean? It used to be all zeros...
  4. Doctor Bob
    Doctor Bob Grandpa
    Mornington Peninsula
    VT V6 Exec & VN V6 Exec
    the Vy has no provision to flash engine codes on the dash, the trouble codes you have there are the instruments only, you need to plug a tech2 in at a dealer to check codes on these.
    Cheers Rob
  5. Aggro_VE
    Lake Macquarie
    A lazy VE
    Do what the Doctor orders, and call him in the morning :)
  6. davleigh
    davleigh New Member
    Vx SS Commodore
    What does that code mean though?
    Sent from my LG-P875 using Tapatalk
  7. Nut Kracker
    Nut Kracker (Nucifrangibulum)
    Echuca Vic.
    VT SS 304ci (195i) 2011 Cruze SRi-V 1.4L Turbo
  8. VY2016
    VY2016 New Member
    Newcastle
    VY S-Pac Commodore
    Hey mate, i know this is an old thread but what was the problem?
    Mine started idleing rough as yesty and stalled itself, when i went to the trouble codes it was the same code.
