SUP3RST4R_DJ
- Apr 30, 2011
- 589
- 5
- 18
- Location
- Orange
- 2011 MY11 Holden VE SSV Ute
thats just an idea of an amp that would work though, you should have a bit more of a look around yourself too, just gotta look for 500RMS
basically with coils there is two types: SVC(single voice coil) and DVC(dual voice coil)
A SVC sub has a set ohm, usually 4ohm, and can only be wired one way, however a DVC has two and can be wired a couple ways, such as in parallel or series to make the subs ohm either higher or lower, people generally go for lower as you can get more power to the sub, like that amp on ebay i linked runs 500rms at 4 ohm, or 1000wrms at 1 ohm
the mm1240 comes in either a SVC or DVC so you may even be able to buy a DVC, run it at 2 ohm on a amp that runs 500rms at 2ohm which could be cheaper, i think
thats my best understanding if ive made any mistakes just correct me and OP i hope you understand that, if not best bet is to research it haha
EDIT: as for 1x 12" or 2x10"
you may feel more bass with 2 10s but it wont be heaps louder, and it will probably cost more and you will need to find a spot for the amp/s, assuming both subs are to go behind each seat
