VY heater , aircon controls
Discussion in 'VY Holden Commodore (2002 - 2004)' started by putz, Apr 25, 2009.
  1. putz
    putz New Member
    vy 11 ss
    HI all ,new to the forum < I was wondering if anyone new how hard or easy it is to convert the knob style heater controls to the electronic style, is the wiring the same etc . Any help appreciated.
    PUTZ
  2. Skooby
    Skooby New Member
    VY II SS
    The way I see it would be you are trying to convert it to Climate control, as that is electronic so to speak.
  3. sp001in
    sp001in vyma100
    QLD
    VY ute
    Putz, Welcome to Just Commodores.
    OK, the question has been asked, and you can always use the search feature to look before you post.
    But in answer to your question how easy it is? It's not easy enough to be worth doing.
    The wiring and plumbing is similiar in terms of power and ground... that is where it ends. The dial controls are mechanical with cables and air hoses. the climate control variety is just that electroically controlled. And while it is not impossible to do, it will be a headache to attempt.
    you'll need to take the bottom console off around the gear lever. remove the radio, source a climate control fascia, source a climate controller Mid to high level BCM, getting your keys reprogrammed to that BCM, engine coolant (climate control dependent sensors) cabin temp sensors. $200-500 depending on where you get it from. then you'll spend most of the day wiring it and working out how to make it work.
    http://forums.justcommodores.com.au...02-2004/13282-climate-control-vy-acclaim.html
  4. putz
    putz New Member
    vy 11 ss
    Now you put it like that it does sound like to much trouble to go and would cause to many headaches, will leave .
    Thanks for the help.
    PUTZ:thumbsup:
